Radiator/coolant light?
Old Jun 27, 2011 | 07:59 PM
Benhamtroll's Avatar
Default Radiator/coolant light?
The radiator warning light in my '84 XJ6 is on and I'm not certain why. I replaced the thermostat (which was needed) and have made sure it's full if fluid, but the light is still on.
Any input on what I should be looking at?
Old Jun 27, 2011 | 10:12 PM
Doug's Avatar
The low coolant sensor is on the brown coolant tank....towards the front of the tank, about 1/3 up from the bottom. Make sure it's plugged in ! If not you may have to search for the dangling wire.
Sometimes the sensor itself gets dirty. It can be removed for cleaning . It presses into a rubber seal/grommet. Better order a new sealing grommet first, though.
The sensor works in conjunection with a transmitter under the dash. These almost never fail. I've never learned how the transmitter works. Might be interesting to open one up one day.
Old Jun 30, 2011 | 12:51 PM
The wire was the culprit. Thanks a bunch!
Of course, I have now discovered that the coolant reservoir has a leak and likes to spray hot coolant all over the insulation. Looks like I'm buying a new tank!
Chris
Jpav27
Jul 31, 2022 06:43 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
redrover41
23
Sep 25, 2015 01:33 PM
avern1
Sep 8, 2015 06:25 PM
Mosers63
Sep 6, 2015 02:53 PM
