Recovering dash pads?
Old Aug 4, 2013 | 10:57 AM
bigdog's Avatar
Default Recovering dash pads?
I'm thinking about trying to recover my dash pad. A little vinyl , a little spray glue-. Has anyone tried this and if so what did you use to fill the cracks in the pad? I can do some expirmenting, but if it's been done no need to reinvent the wheel.
Old Aug 5, 2013 | 11:40 AM
Roger Mabry's Avatar
Default Fill the cracks and cover with thin foam
I have had two pads recovered. The shop first used filler on the cracks after sanding them down flat...then put thin upholstery foam over the whole
thing.
Then vinyl or leather was used for the finished product. Buy the new rubber ends if you want a "deluxe" product...hard to get installed but looks much
better.
Use a solar window cover afterwards to protect the new pad this time....
Old Aug 6, 2013 | 05:18 PM
bigdog's Avatar
Thanks for the response, what I'm trying to find out is what they used to fill the cracks.
Old Aug 6, 2013 | 08:29 PM
anjum's Avatar
There's a guide here DIY Cracked Dashboard Repair [Pic Heavy]
Old Aug 9, 2013 | 06:35 PM
bigdog's Avatar
Thanks for the information, that really answers all my questions. When I get a chance to try this I'm going to try filling the cracks then recovering the pad with vinyl. The XJ6 pad is a simple enough shape the I should be able to get it to form ok. If not it could be taken back off and repiared with the procedure shown in the link.
bdboyle
Sep 16, 2019 05:58 PM
GGabriel
Nov 22, 2018 03:53 AM
the guardian
Sep 25, 2015 03:06 PM
Tim Goz
Sep 17, 2015 09:11 AM
1964Daimler
Sep 9, 2015 11:28 AM
