Red Line Tires
Old Apr 16, 2025 | 08:55 AM
yachtmanbuttson's Avatar
Default Red Line Tires
I'm back at it again. I've replaced my tires with Continental Control Contact 215/65/15's. As they are not available with Red Lines, I have glued on a Red Line product from https://tredwear.com/
I've installed these before with relatively
good luck. But if a tire sidewall doesn't have a good line to follow around the sidewall, if can be a "wavy" install. This time around I decided to search for a 18" round pattern to follow for a perfect circle. It could be a 18" round pizza pan, or a 18" round drum cymbal or whatever. I settled on a 18" round wood you can pick up at any hobby/crafts type store. Be careful though, because the wood is really particle board and the glue that you apply to the back of the Red Stripe will soak into the particle board, and the board will be glued to the tire. I had to paint the outside diameter to keep the glue from soaking in. But... I REALLY like the perfect circle outcome.
Old Apr 16, 2025 | 09:24 AM
Thorsen's Avatar
Show us the finished product!
Old Apr 16, 2025 | 09:57 AM
Old Apr 16, 2025 | 10:02 AM
Thorsen's Avatar
That's a good look and has the right look for your coupe!
Old Apr 16, 2025 | 10:09 AM
Thank you! Next will be a double thin red pin stripe above the chrome belt line.
Old Apr 16, 2025 | 01:30 PM
Jose's Avatar
Coker Tire in Chattanooga sells the red line tires but too expensive.
Old Apr 16, 2025 | 01:34 PM
And they are POS's!!! Had a set and they were crap! Had bulges, wore terrible! These Continentals were $413 installed.
Old Apr 16, 2025 | 04:04 PM
slofut's Avatar
That's pretty damn cool! I didn't know you could do that, they flex ok with the tire and stay put?
Old Apr 16, 2025 | 11:53 PM
The first set I glued on years ago stayed on for years. You are not supposed to use any kind of tire shine on these stripes. They will get blackish marks on them.
craft
E type ( XK-E )
Mar 31, 2025 12:18 PM
yachtmanbuttson
Sep 24, 2019 07:28 AM
Daytona
E type ( XK-E )
Nov 14, 2018 12:58 PM
Dick Steinkamp
Jun 11, 2013 10:43 PM
Skid Mark
Nov 6, 2011 10:06 AM
