Replacing ignition switch with ON/OFF switch and starter button?
Old Nov 20, 2009 | 04:06 PM
m0t0rm0uth's Avatar
Default Replacing ignition switch with ON/OFF switch and starter button?
1976 XJ12L
Ignition switch doesn't stay in ON position (without tape wrapped around it and the steering column).
I'm guessing that it wouldn't be too hard to replace the ignition switch with an ON/OFF toggle switch and a push button for the starter.
I'm too cheap (poor?) to buy a new ignition switch, so I may go that route. Is there a security feature that I have to be aware of that might not let this work? Anyone want to shed some light on this subject that might make it easier for me to accomplish this?
Old Nov 20, 2009 | 05:24 PM
Thermo's Avatar
Veteran: Navy
Motor, the only problem I see is that in most cars, the steering wheel is locked into position by the ignition switch. So, what you would need to do at a minimum is to install the key and turn it to the accessory position. This will unlock the steering wheel and let you drive the vehicle. Then, this will also allow you to control the voltage going to the momentary push button for the starter. Then the ON/OFF button would supply power to keep the motor running. But, again, it would be one of those things that the ON/OFF button really would not be needed if you wired up the power to the ON/OFF switch to the ACC position. Then you can leave the switch in the ON position. That way with the ignition switch in the OFF position, the ON/OFF switch would have no power, garanteeing the car can't run. Then to start, all you would have to do is rotate the ignition to ACC and push the "START" pushbutton. Then for a bit of added security, you can turn the switch to OFF which would still allow the car to crank the engine, but because the engine is not getting any power, it will not start. It will confuse anyone trying to break in.
If you need more ideas, let me know. The only thing that I would possibly caution you on is overloading the one layer of the ignition switch, but this can be overcome simply by using a 30 amp relay and bypassing the contact for the RUN position. Then the ON/OFF switch would only need to be a low current switch as it would be controlling the activation signal to the relay (which is getting the control signal from the ACC power).
I could draw out the circuit for you if this is too much information or you just aren't getting the idea that I have. The nice thing about all this wiring is that it would all be under the dash and should be pretty easy to reverse if you ever get a new ignition switch.
Old Aug 19, 2023 | 01:16 PM
denis4x4's Avatar
Need the diagram to install a push button starter. No problem to use the key for power and as the steering lock. I know this is a very old thread, but hopefully someone will respond with the info I need. Thanks in advance
Old Aug 19, 2023 | 01:43 PM
Doug's Avatar
You have a Series II car?
I am assuming the basic circuit is the same as a Series III, which I am familiar with. What you'd need to do for a starter button, in simplest form, is apply 12v to the white/yellow wire found at the ignition switch.
So, clip the white/yellow wire and run it to one side of your starter button.
The other side of your starter button needs a 12v "+" source. Tap into any solid brown wire under the dash (including the one at the back of the ignition switch) and run a wire to the starter button.
denis4x4
Aug 16, 2023 07:22 PM
Artfulkatana
Feb 14, 2023 11:59 AM
tedjan
Oct 30, 2021 02:09 PM
82jaguarxj6
Jun 24, 2020 11:09 AM
Darrenmb
Jun 4, 2016 09:05 AM
