S3 87 Charcoal Canister
Old Nov 19, 2018 | 07:22 PM
chrisleg's Avatar
Default S3 87 Charcoal Canister
Hello!
Working my way around the car and changing a few hoses etc
Could someone please tell me how often should one change the charcoal canister, if ever or can it be cleaned???
What type are the hoses and ID? Are they of a special type?
Also Do i need to change the valves that are there also?
Thank you!
Old Nov 19, 2018 | 07:42 PM
I don't know Anyone who has Ever changed out the charcoal canister.
Ever.
On Any vehicle so equipped.
It merely needs to be present to satisfy the Smog Cops. They don't care if it actually works (in most areas but your location may be different) and it has no effect on engine performance.
Hoses are nothing special other than vacuum hoses of good quality and condition (vacuum leaks cause rough running as I'm sure you're aware). They're not expensive and are available at just about any parts house.
If you're unsure of the size, clip off a short length as an example and take it to the store. It's sold by the foot.
Someone familiar with Series 3 specifically will have to comment on the valves. Generally though, if they rattle they are working fine.
Old Nov 19, 2018 | 08:19 PM
chrisleg's Avatar
Ever.
Thanks for the info LnrB
I will have a close look at it this week, work forgiving.
I have a NAPA store around the corner so will take a sample as you suggested.
Old Nov 20, 2018 | 04:50 AM
Jose's Avatar
I changed mine one time just for fun. The new one was shiny clean and it looked nicer.
But not the hoses or check valves. I did paint the bracket though.
Old Nov 20, 2018 | 09:30 PM
chrisleg's Avatar
Hi Jose!
I plan to change up the hoses and clean out the valves while i am at it.
Was going to get a new canister but the more i look around and read the less i think its necessary. But who knows. If i get one new dirt cheap i may do it!
Old Nov 21, 2018 | 04:36 AM
Jose's Avatar
Chris, no maintenance is required on the charcoal canister or the check valves or even the hoses,
what you could do is go to an Aquarium supply and get the charcoal bags they sell, it is the same principle. You would have to open the canister to replace the charcoal and the result is: nothing gained.
Elbartus
Dec 27, 2021 03:49 AM
AustinS '76 XJS
Jul 18, 2015 07:25 PM
Vee
Jul 13, 2014 12:15 PM
aspinfo
Dec 5, 2013 04:44 PM
jagstein
Feb 25, 2010 11:56 PM
