Salisbury or Dana Diff?
Old Apr 14, 2014 | 08:08 AM
o1xjr's Avatar
Default Salisbury or Dana Diff?
Going by my book I have Salisbury diff, Vin 1L30046BW. Went to parts store, they think I would have a Dana diff(going by the "Hexico" pinion seal part number I gave them), Can anyone tell from the pics.
Attached Thumbnails Salisbury or Dana Diff?-dsc_8968.jpg   Salisbury or Dana Diff?-dsc_8970.jpg   Salisbury or Dana Diff?-dsc_8973.jpg   Salisbury or Dana Diff?-dsc_8982.jpg   Salisbury or Dana Diff?-dsc_8950.jpg
Old Apr 14, 2014 | 08:19 AM
Doug's Avatar
The question usually comes up relative only to mid-80s XJSs. In those cases the mystery is simply solved: Dana manufactured diffs don't have a drain plug; Salisbury diffs do have a drain plug.
AFAIK your Ser I would not have anything but a Salisbury, and from the pics I see that you do have a drain plug.
However....
The situation gets bit confusing as even the Salisbury made diffs are a kissin' cousin to the widely used 'Dana 44' differential. If any of the parts, including seals, look 'Dana-ish' and/or are cataloged for use in Dana differentials, it wouldn't be surprising.
Old Apr 14, 2014 | 08:34 AM
o1xjr's Avatar
Definately has a drain plug, and a Jaguar mechanic(40+ years experience) said it was a salisbury, Just the girl at the parts store put doubt in my mind. But in saying that she has been there quite a few years and has always been right before.
I've been using the same shop for 16 years and she has been there at least half of that.
Update, I should Know about the drain plug thing as my Jeep has 2 Dana diffs and no drain plugs major PITA
Old Apr 14, 2014 | 09:36 AM
JagCad's Avatar
If you have a four wheel drive oriented shop in your vicinity, they can probably make a
positive ID.
At one time, Spicer was a source for very similar differentials in domestic.
So, indeed, the geneaology is probably intertwined.
Your project is looking great.
Parts for old critters, always fun. I started a quest for a pair of spindle nuts for the VW semi derelict dune buggy in my drive. LH metric!!! I can only guess that it was made on a pan of early 60's vintage!! And, if I need a die to chase the spindle threads, that oughta be more fun!!!
The Jaguar was our transportation of choice yesterday. Coco likes riding in it. Not so much in the Jeep. I think he relates the latter to a dog catcher truck. Doesn't like getting in, but once in is OK.
Carl
Old Apr 14, 2014 | 11:32 AM
icsamerica's Avatar
AFIK and based on my experience, the Dana seal will not work. You need part number CBC006923. From my recollection when I tried this...The Dana seal will physically fit but had the Lip in wrong place so it wont seal properly on the pinion shaft.
Old Apr 14, 2014 | 09:54 PM
o1xjr's Avatar
I need to identify diff because bearings are burnt and oil seals melted from the fire.
https://www.jaguarforums.com/forum/a...m-fire-115245/
Attached Thumbnails Salisbury or Dana Diff?-dsc_8980.jpg   Salisbury or Dana Diff?-dsc_8983.jpg
RaceDiagnostics
Jul 7, 2022 06:41 AM
BoarHawg
Dec 14, 2015 12:21 PM
xk8don
Sep 22, 2015 07:41 AM
AtholC
Sep 9, 2015 09:07 PM
