Series 1 hub cap questions
Received 6,317 Likes
Mine have mallet marks from a PO, it's all about technique I guess. I just do it the way I watched my Grand Dad do it.
Received 2,399 Likes
I dimly recall hub cap days. In the late 40's, I worked at a full service gas station.
fixed flats, a lot. Cars either had hub caps or were bare...
I still have a cap from a 40 Ford. And an assortment, no sets of "beauty rings". later vintage, though.
The early tire irons had a fitting for the lug bolts on one end, and a flat on the other to pry off hub caps. As I dimly recall, a thump with a fist placed just right seated them The side opposite the thumb....
Carl
Carl
Series 1 with XJ40 wheels
Every time I try to load a picture of the car with the wheels, IE crashes?
Best I can do is give you a link to my OneDrive...
https://onedrive.live.com/?id=4437CF...2B033E&group=0
These wheel fit the rear fine, the front has to have wheel spacers and longer lug nuts. S1 front hubs are different from S3... spare tire has to
be stock sized or the wooden cover will not lay flat since the wheels are seven inches wide.. I am getting a Jag XJR compact spare very soon.
edward r (01-04-2024)
caps
On the posts for the hubcaps, you'll find slots cut around and near the top of the posts. set the cap rim on 2 of these slots so that it is raised ( do not place the cap against the wheel ). Doing this allows the cap to "stretch" over the 3rd post and will save from sore palms and dents. Hope this makes sense,
Jim
Jim
WTB[NorthEast]: need xjs part
reichstall
11-02-2015 10:37 AM
Seann1212
10-28-2015 09:13 AM
