Series 2 LSD oil
Old Feb 4, 2025 | 05:35 AM
mickvic's Avatar
Default Series 2 LSD oil
Hi I have a 1975 series 2 and looks like ive got an LSD. Jack it up rotate one side forward and the other side goes forward as well. Can I ask what oil I should use in it? Like everything else on this new (to me) car Ill have to assume the previous owners have conducted some poor maintenance even if they have done well. Best to be on the safe side.
Old Feb 4, 2025 | 05:57 AM
iramphal's Avatar
Would a Canadian XJ6 Sovereign have a LSD?
Old Feb 4, 2025 | 06:31 AM
Doug's Avatar
Nothing exotic required. I'm not sure what brands are available in your area.
I use any name brand 80/90 gear oil and add a limited-slip additive. Some gear oils are already limited-slip ready and say so on the label
Valvoline Gear Oil, Differential, 80W90, Conventional, 1 qt Bottle, Each
Trans-X Posi Trac Limited Slip Gear Oil Additive | 7 oz
Old Feb 4, 2025 | 06:36 AM
Doug's Avatar
Probably not. Very few six cylinder cars have it.
LSD was standard on V12 cars. As far as I know it was always optional equipment on sic cylinder cars
Old Feb 4, 2025 | 07:01 AM
Darrenmb's Avatar
Veteran: Navy
My 83 had it, but no telling if it was part of an option package or someone swapped it in!
Old Feb 4, 2025 | 03:05 PM
sov211's Avatar
[QUOTE=iramphal;2821667]Would a Canadian XJ6 Sovereign have a LSD?[/QUOTE
YES, it has the LSD.
Old Feb 5, 2025 | 12:24 AM
Jagboi64's Avatar
Yes. The Sovereign had LSD, the XJ6 did not. All Canadian V12 cars had LSD.
To confirm, under one of the bolts that hold the rear cover on should be 2 tags. One for the gear ratio and the other will have PL for power Lock, i.e. limited slip.
Old Feb 5, 2025 | 02:50 AM
mickvic's Avatar
Here we go : https://penriteoil.com.au/product-se...ecommendations
penrite diff oil 80w /90 G08090001 has a built in additive so suitable for LSD
Thanks for help everyone
Old Feb 5, 2025 | 07:58 AM
iramphal's Avatar
Thanks to all who responded to my Sovereign LSD question. Sounds like I need to crawl under the car and check for those tags. Unfortunately it is +3 deg. C or 37.5deg. F in ny garage, so that check is now on hold for a bit.
As an aside, is it detrimental to use an LSD designed gear oil in a non-LSD unit?
Old Feb 5, 2025 | 10:15 AM
Jagboi64's Avatar
Not at all, it will make no difference.
zedtt
Apr 8, 2022 01:32 PM
Mitzyspruce
Oct 16, 2021 07:01 PM
jag68
May 24, 2017 07:38 AM
NathanDD6
May 19, 2016 11:57 AM
trymes
Mar 16, 2013 12:55 PM
