Series 3 4.2L High Idle Speed
Old Jul 15, 2018 | 01:25 PM
twocross's Avatar
Default Series 3 4.2L High Idle Speed
Hello everyone,
One of my last bits to sort on my Series 3 4.2L is getting the idle speed to the factory spec which is I think is 550rpm (could be wrong on that). It’s currently at ~1200rpm. I’m having trouble finding the proper procedure for setting the idle. Any advice?
Thanks in advance!
Old Jul 15, 2018 | 02:18 PM
Doug's Avatar
Here's a little something
Idle Speed Adjustment
Post back if no joy
Old Jul 16, 2018 | 09:14 AM
twocross's Avatar
Thanks Doug. I have the idle speed set at 850 rpms now. Smoothed our considerable. I checked for air leaks by lightly spraying mass air flow sensor cleaner at the areas that air could enter, found no leaks. I turned in the idle screw (7/32” Allen) all the way in and that’s what got me to the 850 rpms. Should it be lower, or is that rpm acceptable?
Old Jul 16, 2018 | 09:39 AM
JagCad's Avatar
For my way of thinking, still a bit fast. My two cars are not jaguar powered. Each idles nicely at 500!! The DOHC needs a bit more. When mine was still DOHC, it was a bit "lopey" at 650. Not an issue, to me at the time....
Carl
Old Jul 16, 2018 | 08:19 PM
Doug's Avatar
850 in "Park"?
If so, that's higher than spec but, honestly, that's about where they like to run. It's certainly not so high as to be a problem. Lower then that they often struggle, in my experience.
It should drop down to about 700 in gear
The fact that that it won't go any lower indicates a fault which should be correctable....with some time and effort. Your decision
Old Jul 17, 2018 | 07:22 AM
twocross's Avatar
The 850 is in park, and it runs fairly smooth. I'd like the ability to get it to spec even if I increase the idle back up to 850. I didn't remove the air distribution body, but I did spray some carb cleaner in it to try to flush out any gunk. Throttle cable has very little slack, so I know that adjustment isn't to blame for the higher than spec idle.
-Alan
Wayne'sJaguar
Jul 22, 2016 06:08 PM
ahunt4
Sep 4, 2015 02:59 AM
formula1vhs
Feb 1, 2015 12:17 PM
Shacks
Mar 15, 2014 09:35 AM
bobaye
Feb 26, 2010 05:56 PM
