Series 3 Transmission mount replacement
Old May 26, 2022 | 05:15 PM
iramphal's Avatar
Default Series 3 Transmission mount replacement
Sorry, I know there are a ton of responses to this topic, but I just received my "spool" and my SNG side mounts, so I think I'm ready to change them all out. Is there a comprehensive and definitve tutorial for this process? I've got the manual and all the comments from other members, but I wish there was a step by step run at it. Especially, the "washers" and the "special shouldered" washer. I understand the Spring tension issue, and if not, perhaps I should just document it myself, but I'm not good at stopping to take pictures. Maybe some CDB oil. It seems to be a good topic for a "documentary".
Wont happen till a week or two, as I need to attend to my Expansion tank leak/rupture issue. Tank arriving in 4 days!
Ian
Old May 26, 2022 | 07:09 PM
Doug's Avatar
The parts catalog illustration, and good notes & photos, will be helpful. Lots of parts to this crazy contraption but it's really just a matter of keeping track of things. It's entirely possible to install things upside down if you don't pay attention. Ask me how I know
You'll need a floor jack to take the weight of the transmission off the mounts.
It's been too many years since I last did Xj6 trans mounts so my memory is too foggy for a step-by-step. Others will chime in
Old May 27, 2022 | 06:33 AM
yachtmanbuttson's Avatar
I never had a "spacer washer" C29011 in mine. Probably removed by PO at some point in the past. Doesn't seem to make a difference though.
dleckste
Sep 2, 2021 07:23 PM
4catstudio
May 8, 2021 08:46 PM
adenshillito
Apr 21, 2021 10:15 AM
PaulOClassic
Jul 11, 2018 07:55 AM
jag_sticker
Nov 25, 2017 12:10 PM
