short curcuit
Old Nov 27, 2015 | 02:44 PM
amaezing's Avatar
Default short curcuit
Alright here's my first test.
I know the battery is a little low, going to put it on the charger but,
Battery reads 12.04 when it's off
jumps from 10.98 to 5.8 when it's running
Alternator reads 12.24 running on the big main lead
.26 on the little wire when off
and 10.98 running
Old Nov 27, 2015 | 03:35 PM
amaezing's Avatar
easy enough i guess. the morons that tested the alternator didn't test it right.
sorry to bother you with this stupidity
Old Nov 27, 2015 | 07:13 PM
warrjon's Avatar
FYI, Battery voltages for a Lead acid
12.70 fully charged
12.20 50% charge
12.00 25% charge
Charging voltage will vary depending on which cycle the battery is in. At 14.5 the battery is charging, once charged the system will float charge at about 13.5v.
These voltages will vary slightly depending on how accurate your meter is.
Old Nov 28, 2015 | 05:41 AM
amaezing's Avatar
Good info Warren. I knew it is suppose to be above 12, just didn't remember what exactly.
mkprator
Dec 1, 2015 09:44 PM
joesoap
Dec 1, 2015 03:47 AM
Jhartz
Nov 27, 2015 08:08 PM
wabisabi
Nov 27, 2015 07:30 AM
Jon89
Nov 25, 2015 02:45 PM
