XK8 Battery drain from Hood left open?
Old Nov 25, 2015 | 06:42 PM
wabisabi's Avatar
Default XK8 Battery drain from Hood left open?
Last Saturday I left the hood up on my '02 XK8 to discourage mice from building nests on top of the engine. Next morning the car would not start, the
battery was drained, although it was a new battery (June) and has started right
up every time prior to this. I could find no light in the engine compartment, nor
any mention of one in the owner's manuals. Does anyone have a clue as to
what could have caused this problem? Is there a sensor that could have
caused it? It's really puzzling me, so any help would be greatly appreciated.
Thanks!
Old Nov 25, 2015 | 08:20 PM
RJ237's Avatar
I often open the hood on my 97 to cool the plastic parts more quickly, and it's sometimes several days before it's closed again.
Never had a problem with the battery, and I even checked once with an ammeter in line and didn't see a higher current.
But maybe the 02 is different.
Old Nov 26, 2015 | 06:07 AM
jamdmyers's Avatar
The only thing I can think the hood open will indicate is when the key is turned on and the mil will indicate hood open but only then. I've had my hood set into service mode for multi days with battery charged and no ill affects.
Old Nov 26, 2015 | 08:33 AM
DaveInVA's Avatar
If your neighborhood is as bad as mine maybe the mice stole your battery...
Dave
Old Nov 26, 2015 | 09:48 AM
motorcarman's Avatar
TSB section has Jaguar issued info. (no body looks??)
Issued over a decade ago this might help track down your problem.
bob gauff
Old Nov 26, 2015 | 12:22 PM
wabisabi's Avatar
Thank you so much to all for your input so far -- I've learned a lot.
Happy Thanksgiving!
Old Nov 26, 2015 | 12:40 PM
wabisabi's Avatar
Thanks for the info. It's really easy to accidentally bump the windshield wiper stalk
when turning on or off the car -- it happens all the time!
Old Nov 26, 2015 | 06:16 PM
Gus's Avatar
Gus
I would check the sleep mode and also the gate on the key when the key is removed. I have often left my trunk and hood open many a time in the garage with no ill results.
Gus
www.jagrepair.com
Old Nov 27, 2015 | 12:21 AM
wabisabi's Avatar
Gus
JagRepair.com - Jaguar Repair Information Resource
Thanks, Gus,
How do I check the sleep mode? I've read here about checking the key gate (flap).
I appreciate your help.
Old Nov 27, 2015 | 07:30 AM
Gus's Avatar
Gus
I am short on time but see if this helps
Link.http://www.jagrepair.com/images/AutoRepairPhotos/Current%20Testing.pdf
Gus
www.jagrepair.com
BlkCat
Aug 1, 2020 03:16 PM
drbsmithmd
Feb 16, 2020 12:06 PM
Louenigma
21
Jun 13, 2016 06:38 PM
achysklic
Nov 25, 2015 02:39 PM
gmacaz
Nov 11, 2015 05:08 PM
