SIII Fender braces
Old Dec 15, 2017 | 08:45 AM
iramphal's Avatar
Question SIII Fender braces
Morning everyone - Minus 12 degrees and 6" of snow!
I want to remove the "V" Fender Braces in the engine compartment for refinishing. Are they statically under compression/tension or can I just unbolt them or do I need to apply some sort of brace?, Ian
Old Dec 15, 2017 | 08:51 AM
Doug's Avatar
Just pull 'em off. Nothing bad will happen.
On reinstalling make sure the bolts are tight.....tighter than you'd normally think would be required...or you'll get some odd clunks as you drive
Old Dec 15, 2017 | 08:58 AM
JagCad's Avatar
Ditto !
The big bolt at the cowl is a bear. A big Nylock nut. 9/16' as I recall. One arm to hold it. Wrench size access limited. And another big socket and rachet for the top one. Use 1/2' drive for leverage, you will need it. 3/8" tools a bit small.
Carl
Old Dec 15, 2017 | 09:03 AM
iramphal's Avatar
Thanks Gentlemen, They always seem to look so beat-up which is a shame as they are such a pronounced feature in the compartment. To a novice they hint at massive power under there! I will hit the garage this evening - Merry Christmas.
Old Dec 15, 2017 | 09:07 AM
JagCad's Avatar
Massive power ????
Merry Christmas to you, Sir !!!
Carl
Old Dec 15, 2017 | 05:24 PM
Jose's Avatar
I remove the Torquing Bars every two years to refinish them with anti-rust Rust Oleum paint because they rust.
ronbros
Feb 4, 2018 03:53 PM
weisberg
Jan 4, 2014 05:31 PM
User 070620
Aug 9, 2012 04:04 AM
racerx82
Mar 19, 2006 11:32 AM
