Stainless steel headstuds
Old Apr 4, 2012 | 09:27 AM
Fraser Mitchell's Avatar
Default Stainless steel headstuds
Looking through one of our English Jaguar club magazines and I saw an advert for high tensile stainless steel headstuds by David Manners, a Jaguar spares dealer. Cost about £130 a set.
I don't know if it includes the 5/16" short ones at the front, but these don't corrode badly anyway.
Old Apr 6, 2012 | 05:03 AM
aussie_ser3's Avatar
its certainly a good idea, but one would hope that if you had to do the head once and managed to get all the studs out you wouldn't have to do it again. even if you did in the next few years you wouldn't expect the new one to corrode would you?
i suppose it would depend on the price difference and if you expect to keep the car for long enough to have to do the head a second time.
Old Apr 6, 2012 | 09:28 AM
Doug's Avatar
FWIW, when replacing a head gasket I seal off the studs right where they exit the block...thus turning "wet studs" into "dry studs".
Old Apr 6, 2012 | 12:48 PM
Yes, this will stop head gluing to block, but I think the main thing with the stainless ones is to stop the corrosion of the length sitting in the coolant jacket. This is the first time I have seen HT stainless studs advertised from a large spares supplier, and the kits are for all versions of the XK engine, short stud blocks included. If it was me rebuilding an XK engine, I think I would use a set because I suspect the extra price over the normal steel items will only be a small percentage of the money needing spending on the engine.
Old Apr 6, 2012 | 01:25 PM
Doug's Avatar
Ah yes...quite right :-)
Old Apr 13, 2012 | 09:49 AM
ronbros's Avatar
something i dont see mentioned of here!
i use EVANS coolant, been in one of my cars for 10yrs, absolutly NO corrosin, none.
no overheating also.
google Evans coolants, read! maybe its me being ahead of the curve again!
Old Apr 13, 2012 | 02:17 PM
BTW, I saw the advert again, and the price says "from £120", so I suspect the long stud set will cost much more than the short ones.
Old Apr 14, 2012 | 10:07 PM
AristoCat's Avatar
EVANS is the Beee's knees...
Ive seen this stuff perform in some of the most agressive heat generating engines in harsh conditions: 103F ambiant air Temps. 143F track Temps. @ Buttonwillow Raceway in a GT35R 13B REW that was bridgeported & running 7500 RPM's throughout the majority of the day...
boiler
US Southwest
Dec 20, 2025 12:38 AM
revauto
Sep 17, 2020 03:50 PM
XJ8JR
Oct 2, 2015 12:13 AM
ChrisJay
Sep 27, 2015 09:08 AM
