Start up after sitting 85 xj6
Old Apr 9, 2024 | 07:46 PM
julien.exe's Avatar
Question Start up after sitting 85 xj6
Hi, I am working on a friend/customers 1985 XJ6 (6cyl) that sat of 8 years I got it to run and drive ( I had to Hotwire the fuel pump from the relay and put in 6 spark plugs, wires, cap and 1 o2 sensor). Then it started. It idles a bit shakey but not too bad. Problem begins when I turn it off it refuses to start again. it has spark, air, and fuel but, it won’t start unless it sits for a few hours.
PS I work on antique cars that are carbed I am not used to fuel injector cars.
Old Apr 10, 2024 | 06:13 AM
Malcolm Ridgway's Avatar
Default Poor starting
If it’s been stood awhile rust in tanks get into fuel filter restricting flow. New fuel filter and clean pipes, also consider extra inline filters. Pump might need changing as well.
Old Apr 10, 2024 | 06:54 AM
Doug's Avatar
I agree that the fuel system probably needs attention. Pull the fuel filter and empty the contents into a clear container. What you see will dictate your next steps.
Brewtech
Aug 6, 2023 12:30 AM
Benkitties
XJ40 ( XJ81 )
Oct 18, 2022 09:40 PM
rcarpenter
XJ40 ( XJ81 )
Mar 15, 2011 01:08 PM
vintagecoils
XJ40 ( XJ81 )
May 15, 2008 12:33 PM
Mar 22, 2007 04:15 PM
