Steering Wheel Modification
Old Apr 9, 2020 | 12:58 PM
purpleporsche's Avatar
Default Steering Wheel Modification
I think the rim of this steering wheel looks right at home in the cockpit. The center (horn button) was quickly tossed together using a familiar part. It might become part of the resto-mod of the XJC. Thoughts?
Old Apr 9, 2020 | 01:37 PM
Jose's Avatar
looks almost like a 1968 MG-B steering wheel.
Old Apr 9, 2020 | 01:49 PM
I’m glad you agree it looks British...it’s heritage is much less distinguished (Mazda). I’ve got to work out a solution for the center and horn, but l like the minimalist look.
Old Apr 9, 2020 | 01:59 PM
JagCad's Avatar
I like the spokes. Remind me of my old Fords. The brown rim, not so much. But, over all, I could learn to like it. I sure do appreciate the better view of the instruments.
But, not a sign of padding. Not that great an issue. Or is it!!!
Carl
Old Apr 9, 2020 | 02:00 PM
Jose's Avatar
the horn button looks like a Kent rim center cap.
is the Mazda splined shaft the same as a Jaguar? or did you fit the wheel to a separate hub/boss?
Old Apr 9, 2020 | 02:08 PM
Yes...it’s a center cap...and no...the 1975 Mazda RX-5 Cosmo donor spline is not a match, but the wheel hole diameter is smaller, so it’s a simple fix to machine it to fit.
Old Apr 9, 2020 | 02:17 PM
Jose's Avatar
so a new larger spline can be machined as long as it is smaller than the shaft's spline?
I want to fit a 1992 XJ-12 steering wheel to my 1965 S type, but the S type's shaft is larger / wider diameter, in other words, the steering wheel from the XJ-12 will not go into the S type's column shaft, the splined hole is smaller than the column shaft.
Old Apr 9, 2020 | 03:14 PM
So...first the disclaimer: I am not a machinist, a metallurgist, nor an engineer. I’m not qualified to advocate for using anything other than OEM steering wheels on OEM shafts. 🙂 That said, there’s nothing mysterious or magical about mating male and female splines. If they don’t match, one or both splines need to be modified to match, usually a process that involves careful boring, and then the application of both heat and pressure. My OPINION is it is much easier to modify the splines on the steering wheel, and certainly less catastrophic if you screw it up. I would NEVER attempt to modify the splines on the steering shaft.
Old Apr 9, 2020 | 03:31 PM
Jose's Avatar
the problem is that I don't know any machinist that could enlarge the splines in the steering wheel and make them match the shaft splines.
But there must be a way.
I use 3 different steering wheels in my XJ-6.
Two Momo and one XJ-S. Depends on the weather which one I use.
Old Apr 9, 2020 | 05:13 PM
Yellow series3's Avatar
I'm not an engineer either but took engineering classes when I was majoring in Industrial Design. At that time (a very long time ago) female splines were cut using a machine called a broach. The correct size hole was bored and then a tool was pressed in that cut the splines. Not unlike a how a tap cuts threads. The problem is that it is a huge hydraulic press that pushes the tool in with tons of pressure. So they are commonly set up for large production runs. I've never known anyone that had the ability to cut them individually.
That being said, there are other ways like using a key or pin. Call me crazy but a steering wheel doesn't get much torque applied, especially with power steering so I would investigate possibly using epoxy. There are some companies that can supply spline shaft bushings or adapters. Just my two cents.
Jeff
Old Apr 9, 2020 | 05:25 PM
Jose's Avatar
Jeff do you mean a reducer or augmenter spline?.
That would work for you since you want the old style of steering wheel of the S type, MK-2, 420, etc., in your Series 3 XJ.
but trying to fit a 1968-on small splined steering wheel into the larger splined shaft of the old models above is impossible unless the steering wheel's splined hole is enlarged and re-splined.
Old Apr 9, 2020 | 05:36 PM
Jose's Avatar
here's some interesting trivia:
the MG-B and the Jaguar E-type used the same identical horn button assembly.
The MG-B from 1962 to 1970, and the E type from ? to 1970. British Leyland days sharing parts. The only difference was the emblem.
Old Apr 9, 2020 | 06:43 PM
Yes, an adapter or bushing would be used to connect a small diameter shaft to a larger diameter wheel. If the other way around you would need to drill the hole on the wheel to a larger diameter and then cut the spline. As you know, when using a tap to cut threads, the first row of threads barely cuts, the next row cuts a little bit more, etc until the tap has cut the proper depth and then it turns easily. The spline cutting tool works like that, it's tapered and cuts deeper as it is pushed in. But it takes enormous pressure to push it through to cut the material. Brass is softer and easier to cut than steel but a hydraulic press is needed in either case.
Jeff
Old Apr 10, 2020 | 03:54 AM
Fraser Mitchell's Avatar
And a little bit more.........
The ash tray on the centre tunnel of the E-type is the same one as fitted to my little MG Midget. Except Jaguar put a little leaper on the lid !!
Old Apr 10, 2020 | 05:20 AM
Jose's Avatar
Fraser how could I forget the famous ashtray ! and by 1969 the MG-B's exact model name was "MG-B MK-II".
MG was not a cheap car. Leather seats, full instrumentation, wire wheels, Excellent electricals, full size spare tire. I love MGs.
Old Apr 10, 2020 | 07:05 AM
Doug's Avatar
I've had two MGs. One I used as a daily driver for a few years. Loved 'em. Maybe one day I'll have another.
Old Apr 10, 2020 | 07:29 AM
Jose's Avatar
my dream car was the MG-A Coupé but I couldn't afford one so I made mine a Coupé with the fiberglass top from AAMCO, the boot rack, Talbot bullet door mirrors, and rubber mats.
I loved the chromed waist moldings of the MG-B. They just snapped on and off, replaced them many times because people dinged them with their car doors.
Old Apr 10, 2020 | 11:59 AM
JagCad's Avatar
Two comments:
1. Search You tube. Broach process. I saw one machinist cutting key ways by the broach process. Imagine a toothed tool going up and down and in. Same process but with a different tool. Cutting v's or notches..
2. My one and only brand new car that I ever bought. 53 MG TD. Had tons of fun in it. I was stationed in Germany at the time. No heater or radio. cold, aye. but no more than my business ride, a Jeep!!
Old Apr 10, 2020 | 12:57 PM
Carl, smiles are kind of rare these days but your comments about your MG brought a smile to my face. I can just see you ripping up the back roads in Germany back in that long ago time. When I was in college I had an MGA. It had a heater such as it was but the top would bulge up when driving fast and creat a gap between the top of the windshield and the front top bow. Snow would blast in through that gap and hit me square in the eyes. I had to wear chemistry goggles to drive when it snowed.
Jeff
Old Apr 10, 2020 | 03:29 PM
Jose's Avatar
an MG-A nowadays is worth more than a Jaguar XJ-6. ironic to say the least. And the MG-A Coupé? To dream. the impossible dream.
I found out my old MG is still running with a Mazda engine. Lumped by 2 brothers who collect Triumph, MG, and Mini Coopers.
