Sunday drive ends with 000, I'm on fire.
Old May 4, 2014 | 03:38 AM
  #101
Originally Posted by o1xjr
............. Get a mate over to bleed the brakes and off we go to another mates exhaust shop to have him cast an eye over the work and refit the rear mufflers and tail pipes. Had to butcher them a bit to remove them. Doe's sound good missing the rear mufflers. .........
Is the exhaust temporarily terminating at the pipes over the IRS?
If so, think about where those hot exhaust gases are aiming - you don't want another bonfire!
Old May 4, 2014 | 05:05 AM
  #102
o1xjr's Avatar
From the front mufflers,pointing straight at the calipers, only ran it for about 10 seconds today. Will push on the pipes that go through the cradle before driving it,just leave rear mufflers off.
Just got to drive it about 1km to the exhaust shop.
Old May 4, 2014 | 05:39 AM
  #103
I'll bet that felt good to be moving again.
Old May 4, 2014 | 05:54 AM
  #104
o1xjr's Avatar
Didn't get to move it,still on stands until tomorrow when I bleed the brakes. just had to start it for the hell of it. But it's getting close to feeling good.
Old May 5, 2014 | 05:03 AM
  #105
o1xjr's Avatar
Default On the road again
8pm, just fitted handbrake calipers and drove around the block.
Off to get the work checked over by mechanic tomorrow morning,and mufflers and tail pipes fitted up. Maybe I can do the easter road trip we planned now.
One month almost to the day(29 days), spent 138 hours on it. Lucky I only work a 3 day week.
Attached Thumbnails Sunday drive ends with 000, I'm on fire.-dsc_9311.jpg   Sunday drive ends with 000, I'm on fire.-dsc_9309.jpg
Old May 5, 2014 | 05:13 AM
  #106
o1xjr's Avatar
Default Back on the road
Done.
Old May 5, 2014 | 06:21 AM
  #107
Been missing a bit lately.
My bos decided he needed a break, so had a massive heart attack, and I have been doing 6 days, 10 hours a day for the last 4 weeks, running this huge hard parts operation, and the "old bones" are certainly giving me some serious grief. He came back today, very lucky man.
AWESOME BLOODY JOB, that is true craftsmanshio, trust me. I am IMPRESSED.
The IRS on these cars is such a forgotten item, and is constantly patched up, with a "get to that later" attitude, and as we know, it never happens.
Old May 5, 2014 | 06:49 AM
  #108
o1xjr's Avatar
Thanks Grant, sitting back having a celebratory JD right now. Once I start a job I can't leave any part untouched,Every nut and bolt came off. Now I have done the IRS the rest of the car is lacking something. Never rebuilt a diff before, that was interesting on a garage floor with the wrong tools.
The only part that left my garage was taking diff parts across the road to my retired mechanic nieghbours press to remove bearings.
You will appreciate the JD hipflask in the attached pic(used as oil breather catch tank)
I only registered this car for 6 months when I got it in December,not knowing if we were going to keep it or if it was a whim attack,it has slithered its way into fleet long term now. I even had to let one of the bikes go to accomodate the budget.
Guess I knew all along since I have wanted a series 1 since I was in primary school.
Attached Thumbnails Sunday drive ends with 000, I'm on fire.-dsc_6281.jpg   Sunday drive ends with 000, I'm on fire.-dsc_6277.jpg
Old May 5, 2014 | 08:47 AM
  #109
Lookie there at that!! Clarke, your garage is empty! And your car is ON THE STREET!!
YAAAAAAYYYYYY!!
I bet you won't be running over branches in the road any more.
Old May 5, 2014 | 08:55 AM
  #110
Done.
Congratulations, Clarke!
Yes, indeed!!
Old May 5, 2014 | 09:29 AM
  #111
JagCad's Avatar
LnrB:
Could not resist. apologies!!
The principle of the school insisted that the teachers under his leadership follow the principles of tutelage of the next generation.
I admit. whenever these word are to be used, I have to stop and think as to which is correct in the intended context.
Sorta like if my belt is too loose, i'll lose my pants.
I always admired linguistic master Harikawa, professor and later senator of our state. Words and their lineage are intriguing.
I've been known to turn a Will Rogers like phrase!!
On point. Yup, my "e brake" needs attention as well. The pictures here are extremely useful.
But, because of my recent misadventure with the ramps, I'll wait a bit.
Carl
Old May 6, 2014 | 03:10 AM
  #112
o1xjr's Avatar
Default Finished!!
Back from the exhaust shop with a clean bill of health from the mechanic and a nicely polished set of over axle pipes and rear mufflers,tail pipes cut off and screwed on now(some fool po welded them on).
He said he had to polish the pipes before he put them back together to match the work already done.
Total outlay of $776.63 AU,cheap for a diff rebuild,caliper rebuild,hand brake rebuild,paint and all parts down to the last split pin and nyloc.
The Jeep is happy to back in its home of many many years after a month of being cast aside for the new cat. Just waiting for it's Trans to be removed to replace the welsh plug at the back of the block under the bell housing.
Old May 6, 2014 | 03:50 AM
  #113
Cambo's Avatar
Well done mate! Have one on me.
Attached Thumbnails Sunday drive ends with 000, I'm on fire.-27022006%2528002%2529.jpg
Old May 6, 2014 | 04:29 AM
  #114
Good news Clarke.
That $$ tally obviously DOES NOT include the cartons of go juice for YOU. Still cheap in anyones language.
Old May 6, 2014 | 04:41 AM
  #115
o1xjr's Avatar
If I added the cartons for elapsed time on said project,the red for evenings and the JD or JW the cost would be a blow-out,no doubt.
My wife calls the XJ6 "Fireball", so change of cars nickname is in order.
Old May 6, 2014 | 06:01 AM
  #116
Great result!
It used to be regular to put just a small spot weld on the rear pipe to silencer joint as these can slacken and rotate in use causing a vibration if it gets too close to the body.
Old May 6, 2014 | 06:32 AM
  #117
o1xjr's Avatar
This wasn't a small spot, welded all the way round.
Old May 6, 2014 | 08:22 AM
  #118
Good news, and that sounds very reasonable compared to how it first sounded.
Old May 7, 2014 | 03:02 AM
  #119
o1xjr's Avatar
Default Spent the day driving
Covered about 150 miles today and all went well,still that uncertainty in the back of your mind that it might ignite again. Put it up on stands again when I got home to have a quick look, all good and nothing burned.
So I finally got to put on the fuel shut off tap I was going to fit a month ago,so I can reverse park on my drive without the fuel gravity feeding down to the carbs and running out onto the drive,if only I had a handbrake cable!
Attached Thumbnails Sunday drive ends with 000, I'm on fire.-dsc_9314.jpg   Sunday drive ends with 000, I'm on fire.-dsc_9317.jpg   Sunday drive ends with 000, I'm on fire.-dsc_9318.jpg   Sunday drive ends with 000, I'm on fire.-dsc_9319.jpg
Old May 7, 2014 | 03:07 AM
  #120
Cambo's Avatar
Looks a lot better now without those red driveshafts
