swap s1 rack into s2?
Old May 12, 2025 | 07:49 AM
mickvic's Avatar
Default swap s1 rack into s2?
Are the series one racks interchangeable with the series 2? In my case a 1971 s1 and a 1975 s2
Old May 13, 2025 | 07:18 AM
icsamerica's Avatar
The tall tower racks are the same except for the Ratio. My understanding this that the S1 rack had a lower steering ratio. But who knows what you actually have... it's possible the S1 rack you have was swapped for an S2 at some point in the last 50 years, Get a look at the part numbers to be sure.
Old May 14, 2025 | 06:22 AM
Robert Laughton's Avatar
If you swap in a S2 short rack, you will need the hoes from the short as well.
The S1 rack as hoses that wrap around and enter from the rear, whereas the short rack's hose goes straight in from the front.
I'm sure you know already you'll need the lower column to match.
Rob
Old May 15, 2025 | 07:47 AM
mickvic's Avatar
Thanks for help gents
farina43537
Mar 6, 2024 07:44 PM
geneo
Jan 31, 2019 11:19 AM
dpe007
E type ( XK-E )
Aug 21, 2017 04:47 PM
itchyback
Dec 4, 2016 03:36 PM
AristoCat
Feb 9, 2014 08:23 PM
