timing chain adjust
Old Apr 12, 2014 | 11:18 AM
wardhill's Avatar
Default timing chain adjust
Hi,
I 've got the "rocks inside the beer can" noise coming from the front of my engine 87 series 3 xj6. I'm attempting to tighten the top chain and have researched the use of the homemade special tool to depress and turn the locking pins. I thought i'd clean the breather screen and pipes as well since recently it looks like oil is seeping from everywhere. Does the breather screen pry right out or is it held in place with something. Also any other tips on this job would be helpful
thanks
Jeff
Old Apr 12, 2014 | 12:05 PM
Doug's Avatar
The breather screen pops right off....unless a previous owner has glued in in place with gasket adhesive, as the screen is sandwiched between two gaskets. Clean the breather *pipes* as well.
The locking pin (singular) is often so gunked-up that it can't be depressed. What I do is just wriggle it out with a pair of pliers and clean it (and the hole) with mild solvent. This requires removing the center bolt and the little serrrated wheel...no big deal. For god sakes don't let the pin or the tiny spring behind or anything else it fall into the engine.
Old Apr 12, 2014 | 01:11 PM
wardhill's Avatar
Thanks Doug
Where is this spring located? behind the pin? will it shoot out if i pull the pin?
Old Apr 12, 2014 | 02:36 PM
Doug's Avatar
Originally Posted by wardhill
Thanks Doug
Yes, behind the pin. It isn't a very strong spring. 'Fall out' might be more accurate then 'shoot out'
Old Apr 12, 2014 | 05:32 PM
Fraser Mitchell's Avatar
Push some cloth packing down below the timing sprocket so if anything does fall, it won't fall to the bottom of the timing chest. You could also buy one of these: -
JAGUAR DAIMER 6 CYL XK ENGINE TIMING CHAIN ADJUSTING TOOL JD2B | eBay
It makes the adjustment job a doddle.
While you're at it, thoroughly clean the little oil mist trap "thimble". You'll find this below the rubber "dome" where the breather tube connects near the round timing cover.
Old Apr 13, 2014 | 06:56 AM
wardhill's Avatar
Thanks Fraser,
I saw that tool and l also found on this forum instructions on how to fabricate my own which I'm in the process of doing. I did not have that thimble part whren I removed the breather cap.I have to find one. in the mean time I'll clean everything else. There's lots of gook
Jeff
dsnyder586
Dec 29, 2024 07:39 PM
RoyLittle0
May 25, 2023 02:38 AM
SD96XJ6L
Jan 12, 2022 04:30 AM
Bowman
Sep 15, 2015 06:54 AM
Bowman
Sep 3, 2015 03:17 PM
