Timing chain adjuster
Old May 11, 2019 | 09:45 AM
ferdy's Avatar
Default Timing chain adjuster
I am trying to adjust the upper timing chain on my 77 xjc. I loosened the nut, pushed in the locking pin and tried to turn the adjuster. does not move in either direction. looks to me like something is seized. any advice is greatly appreciated.
Old May 11, 2019 | 12:56 PM
motorcarman's Avatar
The upper chain 'eccentric' adjuster is seized with carbon buildup.
You might try a solvent like 'carb cleaner' dripped in the cup-like area above the adjuster.
Then work the shaft back and forth.
I have seen 'punch-marks' in the holes for the factory adjusting tool by a previous owner.
The worst one I worked on was a 1952 MK VII (3 and a half liter).
I had to remove all the components and soak them in solvent.
The parts finally came apart for re-installation and adjustment.
bob
Old May 11, 2019 | 01:48 PM
Welcome to the forums ferdy,
I've moved your question and another you posted earlier from General Tech Help to XJ6 & XJ12 Series I, II & III forum. This is the place to post technical questions about your 1977 XJC.
Old May 12, 2019 | 05:02 AM
I agree with Bob,
I have had a few jammed up, and I use a "brew" of 50/50 ATF and Diesel Fuel, fill that cup thingy, dribble it around the general area, keep an eye on it and fill as required, and after a day or 2, sweet as a nut. Adjustment possible.
Drain and refill the engine oil with a good quality oil and new filter.
Lack of use, and poor oil changes is the root cause here.
Old May 12, 2019 | 11:39 AM
ferdy's Avatar
Thanks to all of your advice. I will soak it overnight and check.
Tony.
________________________
Calgary ,Alberta, Canada.
1977 xjc.
OnFire
Oct 20, 2020 04:34 AM
iriddles
Feb 1, 2019 07:05 PM
JensenHealey
Feb 1, 2019 01:58 AM
JensenHealey
Jan 28, 2019 06:24 PM
Feb 19, 2008 06:58 PM
