85 Series 3 Inline 6 / 4.2 Mass Air flow Question
Old May 11, 2019 | 01:41 AM
Parker's Avatar
Default 85 Series 3 Inline 6 / 4.2 Mass Air flow Question
Deleted
until coming up with a better picture from the S57 Doc
Thanks Doug for the tip
Old May 11, 2019 | 03:05 PM
Doug's Avatar
What you're seeing, probably, is the 'cold running' modification, designed to prevent over-fueling when cold....although many have reported a general improvement in behavior hot or cold
XJ 6 Series III 4.2 - Cold Start EFI Overfuelling
I suggest using the wiring diagrams from the S57 Wiring Guide. It's in one of the sticky threads at the top of this section
Old May 12, 2019 | 11:51 AM
Parker's Avatar
Can't find S57 wiring guide that opens up to get to the MAF diagram
I did see the TSB on Cold Start EFI Over fueling on pin 6 and 8 with a 100uF capacitor
Old May 12, 2019 | 01:45 PM
kudzu's Avatar
Hi, here are the links to Jose's main site ( the guide is under the "contact/manuals/links tab at bottom ).
Jag Upgrades Home
Here's the direct link to the manual download.
https://static.secure.website/wscfus...ries-3-xj6.pdf
All thanks to Jose, nice to have a digital version to backup my paper copy purchased years ago.
Cheers !
Brian
Old May 12, 2019 | 10:44 PM
Parker's Avatar
Thanks Kudzu ,
Found the area of interest on page 53
which will make a much better picture
Steve Mileman
XF (X260)
Oct 21, 2021 06:26 AM
Spurlee
Feb 10, 2011 10:15 AM
Greg561
May 14, 2009 02:27 PM
Spurlee
Apr 29, 2009 09:51 PM
Xistnnn
Feb 27, 2009 12:58 PM
