Tranmission shifter
Old May 16, 2015 | 09:53 PM
Mad Matt's Avatar
Default Tranmission shifter
Hi guys sorry been busy but old lady J traveling well. One problem that has popped up is the shifter will not allow me to start the engine unless positioned between drive and nuetral. Whats the fix?
Old May 17, 2015 | 12:22 AM
Doug's Avatar
Sounds like the neutral safety/reverse light switch needs adjusting. On your car it'll be on the side of the transmission.
Here's a write up on adjusting the switch to make the reverse lights operate. The same basic method is used to adjust the switch for proper starting
Adjusting Backup Lamp Switch, Series III XJ6
Some switches were not capable of being rotated. In that case the switch must be removed and the screw hole lengthened to allow the switch to pivot
Old May 17, 2015 | 04:20 AM
Mad Matt's Avatar
Thanks need to visit a friend with car hoist.
n2audio
19
Jan 20, 2025 09:35 PM
adam699
Oct 13, 2015 05:53 PM
Johnken
Oct 2, 2015 10:12 AM
Johnken
Oct 1, 2015 05:07 PM
