Transmission "CLUNK"
Old Sep 28, 2022 | 05:28 PM
George M.'s Avatar
Default Transmission "CLUNK"
Car drives fine, but once warmed up, I get a clunk when shifting from neutral to drive or reverse. Where should I start?
Thanks,
George
Old Sep 28, 2022 | 06:00 PM
U-joints.
Jack it up or get it on a lift and see how much slack is in each one.
Old Sep 28, 2022 | 06:15 PM
Fraser Mitchell's Avatar
Engine tick-over speed, (too high), can also cause a clunk when selecting a gear. Is this within the define revs for tickover ?
Old Sep 28, 2022 | 08:04 PM
Doug's Avatar
Also check your transmission mounts and spring....and the infamous cylindrical foam cushion.
Assuming a Series III 4.2 the set-up looks like this:
The rubber mounting blocks get oil-soaked and become weak and saggy. The CAC3227 foam cushion just.....falls apart.
max224
Jan 3, 2022 06:51 AM
rts1021
Oct 3, 2020 09:19 AM
osagie
Oct 3, 2014 07:02 PM
jcordova
Aug 23, 2013 08:03 AM
Striker27
Sep 11, 2008 12:06 AM
