Transmission kicks into D and R
Old Aug 19, 2012 | 11:46 PM
Doug's Avatar
The over run spring is illustrated incorrectly in [at least many] Jag publications. As I recall it will only fit on way.
But, if yours was installed opposite of what's shown in the manuals, it's almost certainly the manual that is wrog.
If the gasket is still in good shape and doesn't leak, re-use it.
Old Aug 20, 2012 | 12:25 PM
e21pilot's Avatar
Doug,
The hoses that connect to the air distribution block (ADB) actually connect to small pipes that insert into the ADB.
Is it recommended to put something like a dab of silicon sealer around the pipes before pushing them into the body of the ADB? I want to avoid any vacuum leak if possible.
Old Aug 20, 2012 | 07:14 PM
Doug's Avatar
Originally Posted by e21pilot
Doug,
For those....and the nipples on the throttle body as well... I use JB Weld
Poet
Feb 7, 2025 02:18 PM
kthrash
Feb 25, 2019 10:20 AM
emilime75
XJ XJ12 ( X305 )
Oct 19, 2015 09:55 PM
Poet
Oct 2, 2015 09:00 AM
Woznaldo
Sep 26, 2015 11:02 AM
