trip computer/fan
Old Aug 3, 2011 | 12:23 PM
doghead08's Avatar
Arrow trip computer/fan
can i get some help on this??
i unplugged trip computer to check if my spare worked. since reconnecting it, it resets every time i turn car off (have to re set clock)
as far as the fan goes...the fan in front of my radiator does not spin when engine is running..is this a problem?
my temp gage usually is either in the green at or a little past the 90 marker
Old Aug 4, 2011 | 05:26 AM
Thinking back here, scary I know.
The trip computer resetting is "possibly" the inline fuse located (memory again) up on top of the unit. I say this due the fact that it sounds like it is losing it voltage that retains memory, just like a car stereo.
The fan in front is I think, and a/c auxillary fan, and a thermo overheat assist fan, so at the temps you mention it should not be working.
Others that are WAY more familiar with S3's will sort this I am sure.
Old Aug 4, 2011 | 07:49 AM
doghead08's Avatar
Default thanks mang!!
my jag does run a little hot, but then again thats there MO
once i get back from doc..im goin to check it out.. i appreciate the assist
Old Aug 4, 2011 | 07:50 AM
Doug's Avatar
'Tis the number 7 fuse (2 amp) in the main fuse box (left side) that provides constant power to the t/c for memory.
The aux fan should come on at 94ēC coolant temp
jagtoes
Oct 14, 2015 06:15 PM
LnrB
Oct 13, 2015 12:45 AM
Joe Gandalf
Oct 1, 2015 01:16 AM
goingjag
Sep 30, 2015 09:27 PM
mrplow58
Sep 30, 2015 08:56 AM
