trouble removing the door panel in front interior
Old Mar 20, 2018 | 11:49 AM
jake delcastillo's Avatar
Default trouble removing the door panel in front interior
1989 xj6
So i feel like im missing a screw when trying to remove the door trim. Ive unscrewed the screw behind the door handle, and the two behind the wood grain, im able to remove the black panel above the leather arm rest, then i find two screws that connect the arm rest at the top and i unscrew those, but it wont budge after that. ive searched all over the trim and havent found any more screws that i could unscrew, am i missing something?
Old Mar 20, 2018 | 12:47 PM
Roger Mabry's Avatar
There are many plastic panel clips, use a tool near each to pop them out. Pry the panel off a little where "stuck" near the bottom to see one of them..
Old Mar 20, 2018 | 01:01 PM
thanks! will that break the panel off? i just get a little nervous, and dont want to break anything else on this car. sorry kind of a newbie here.
Old Mar 20, 2018 | 04:44 PM
Fraser Mitchell's Avatar
Originally Posted by jake delcastillo
1989 xj6
Isn't your 89 XJ6 an XJ40 series model ? If so, you will be better posting in that forum, as there are no doubt differences with the door panel fittings. However post a photo, and I'll take a guess at it !
Old Mar 20, 2018 | 10:06 PM
you are absolutely right, I had no idea about the differences. Thank you so much I will move on to the xj40's
djgold
Nov 3, 2012 02:15 PM
manicguitarist
Jun 2, 2012 04:58 PM
Dmax
Mar 24, 2012 06:00 PM
Adam78
Jul 6, 2011 10:31 AM
benebob
Jul 13, 2010 05:50 PM
