turn signal switch
Old Oct 14, 2020 | 11:18 AM
jaguar jon02's Avatar
Default turn signal switch
someone tried to steal my 1987 ,messed up the turn signal switch, switch has numbers on back of new one , anyone know what wires go where?
Old Oct 14, 2020 | 11:23 AM
Jose's Avatar
the switch comes with a plug that plugs into another plug, the wires aren't loose. ? ?
Are you thinking the HAZARD switch?
Old Oct 16, 2020 | 06:22 AM
sorry, yes my mistake
Old Oct 16, 2020 | 06:49 AM
Jose's Avatar
I have a diagram of the wiring connections at the Hazard switch.
Will post it later when I find it.
Old Oct 16, 2020 | 07:38 AM
Jose's Avatar
Hazard switch wiring XJ-6 Series 3 (1979-1987) Also XJ-12 Series 3:
Old Oct 18, 2020 | 07:37 AM
boy thanks best one i;ve seen, now maybe i can gat back on road
Old Oct 18, 2020 | 08:36 AM
Jose's Avatar
in my website I have more troubleshooting info. and docs about the Series 3 XJ-6.
https://jagupgrades.webstarts.com/
Old Oct 22, 2020 | 06:06 AM
got the hazards working but no turn, called myself jumping green/red from switch and still nothing, looked on line for a new one but they all show a small plug in, mine has a 8 pin plug, hazard and turn use same plug.
Old Oct 22, 2020 | 07:28 AM
Doug's Avatar
Not quite clear on what you've written.
What happens when you use the turn signals? Nothing at all? Do they light up but not flash? Or...?
Have you check the turn signal fuse?
The switch is AEU2802
Old Oct 22, 2020 | 05:31 PM
thanks Doug, looks close to mine ,but i don't have those extra wires i think . know i don't have the single wire from the plug, (not used?), doing a valve job on a honda now ,will look sat i hope
Old Nov 8, 2020 | 05:14 PM
got another turn switch ,all back together, but now horns blow when i turn key on, never used horns but they were bad so put more on, had to use ones off 1999 xj8 two wire
Griff79
Aug 11, 2020 12:09 AM
jeffinpa
Jun 11, 2018 05:42 PM
Morey
E type ( XK-E )
Aug 30, 2014 11:24 PM
marvin1960
May 24, 2013 08:35 PM
Waterwalker
XJ40 ( XJ81 )
Mar 17, 2009 06:43 PM
