V12 cylinder heads
Old Feb 23, 2016 | 06:59 AM
NathanDD6's Avatar
Default V12 cylinder heads
Hi all
I'll be needing to the the left-hand head off...
First cause for concern seems to be around the exhaust manifold... Does this come off before or after the heads? Any special tricks for this?
Second cause for concern is the timing chain tensioner... Sounds to be a fragile thing... I'm keen to leave this item alone as much as possible... Some chap apparently managed to get the heads off without messing with it... Possible? I'll attach the link. If anyone can clarify this I'd be most grateful.
Building the Legend | V12 Head Removal
Cheers.
Old Feb 23, 2016 | 08:48 AM
icsamerica's Avatar
You may want to explain the situation in the XJS forum. The are a lot more v12 owners with experience, The XJS had a V12 exclusive up to the early 90's where as the V12 was relatively rare on the sedan.
ericjansen
Sep 25, 2019 07:10 PM
melhookv12
Feb 24, 2016 07:58 AM
AHudson
E type ( XK-E )
Feb 22, 2016 09:40 PM
NCJagman
Feb 22, 2016 05:12 PM
Chadly
Feb 19, 2016 05:30 PM
