V12 header sources
Driven Man is now part of American Powertrain. At the time I talked to American Powertrain last year, one guy was assigned to the Tremec kits for Jags. I have purchased from American Powertrain in the past. They were always helpful to me.
Hi,
I have a 1975 XJ12C V12. I have been a motorhead for 42 years but I am new to Jag ownership. I believe that it is a good thing to improve airflow through an engine and a good set of headers generally helps if everything is set up correctly. I have been told that the stock V12 exhaust manifolds work pretty well and that headers are not worth the effort. But I am still looking around at my options. So far I have found a company in England and Australia that offer V12 headers. The Australian ones are more expensive but look to be a far better design imo. Are there any other sources to a quality made exhaust header for a V12 for my chassis that anyone can direct me to? Second question, how do I get the Australian piece to the US if I d not find any good alternatives? I have no knowledge about what the shipping options are. I checked with Fed Ex and it was a $6,300 bill. Obviously I am not doing that. DHL came in at something like $2300 but that is still pretty expensive. If I remember right shipping from England was less than $100 so I am hoping there are other options and I'd like to avoid any CA ports if possible.
TYIA
Chris
TYIA
Chris
That means overheating. The radiator works by air flowing through the radiator, picking off heat and on out below the engine. If that exit is blocked off by tubing that will reach up to 1200 degree f You’ll have heating problems.
Second additional power, you will gain at most 4% more. The stock manifolds are very good indeed, plus they only weigh 4 pounds each. ( total 16 pounds).
If you want improvements polish the raw cast iron up and have them thermal coated. Silver is traditional but they also have black and red. That not only gains you a slight power increase but retains the heat to exit out the tail pipe rather than in the engine compartment.
It’s all common sense. V12 in not V8 so the exhaust is not Siamese. Look at the firing order of the V12, you will see that every 180deg one cylinder exhausts into 1 cast iron manifold, and so on. They alternate between the 4 manifolds (180/1 180/2 180/3 180/4) and no exhaust stroke overlaps in those 4 cast iron manifolds. So not Siamese. Now on a V8 , or the Jaguar straight 6 (exhausting into 2 cast iron manifolds) you have overlapping, meaning for a short time 2 cylinders exhaust into the same plenum.. (one pushes exhaust gases into the other cylinder trying to exhaust). Then you sort that out with length of tubing on headers (noting the speed of exhaust gases, and distance traveled) So on a V 12 all you need is 4 independent manifolds. That’s it ! They are plenty big. Headers on a V12 shouldn’t exist. There is NO need for them. (Unless you try to route exhaust gases around an obstacle). All you need to avoid is a Siamese situation.
Now if you want to make it good you make it a quad exhaust pipe set up. So each manifold exhausts into one tube ALL the way to the outside, but you can also do the math and figure out (distance traveled/ exhaust gases speed) then you can merge the 4 manifolds into 2 pipes think a zipper , and that’s what Jaguar did. When they meet they zip together without Overlap. So when you put your hand on the exhaust it should feel like a steady stream of wind. Not puff puff puff puff.
IThat’s it ! They are plenty big. Headers on a V12 shouldn’t exist. There is NO need for them. (Unless you try to route exhaust gases around an obstacle). All you need to avoid is a Siamese situation.
Imagine a TWR 6.0 with the 5 speed and a few aluminum bits to get the curb weight down 400 Lbs. An aluminum hood, alu A/C compressor and alu radiator would have take 100 lbs off the nose alone. All those bits were readily availabe in the late 80's. Another 100Lbs for the 5 speed. The next 200 Lbs is a bit harder to find but it should be practical for a OEM to have done it.
