Vacuum Hose
Old Oct 28, 2012 | 11:11 PM
TonySpumoni's Avatar
Default Vacuum Hose
1974 XJ6, Have an issue finding where one of the Vacuum hoses is supposed to attach. It's on the thermo vacuum switch. Have no idea where its supposed to go. I've attached a parts layout photo to show what I'm talking about its the closer line 38, coming off part 36. I know one of them goes to the manifold under the engine but the other I don't know.
Any help would be appreciated, as my engine is idling at about 3000 at the moment and I believe this may have something to do with it, or the carbs need serious adjustment, or something else/
File Type: bmp
Old Oct 29, 2012 | 07:10 AM
Tony,
No idea where that hose might start or finish, as we did not get that complicated set up down here.
However, for a carby car to be idling at 3000rpm, almost half throttle, there is something SERIOUSLY wrong with the carbies. A vac leak on them would not give that much rise to the idle speed.
Due to age, has it still got the Stromberg CD carbies, or has it been converted to SU carbies. That would be helpful in trying to sort carby issues.
Old Oct 29, 2012 | 07:23 AM
Yes it still has the Stromberg carbs in it
Old Oct 29, 2012 | 08:49 AM
Thanks Grant, so do you or anyone else have any suggestions on getting the idle down on the carbs? I've messed with the idle set screws and the throttle set screw and it dosen't seem to do much good, I'm pretty sure the gas mixture is to rich, any tips?
Old Oct 29, 2012 | 04:20 PM
Could someone with an xj6 carb, or not please look under the hood and see where the vacuum hose goes and tell me
Old Oct 29, 2012 | 06:51 PM
denraden1's Avatar
This is what I used for my Series II engine. It worked great for me. Print and connect as shown.
File Type: doc
Old Oct 29, 2012 | 07:02 PM
denraden1's Avatar
FYI. The diagram is for a RHD. The thermal vacuum switch gets vacuum on port 1 closest the manifold. The other ports open when the proper engine temperature is achieved. One goes to the air pump diverter valve, the other goes to the charcoal canister solenoid and the other goes to the air cleaner. If need be I can take some pics of my engine if you have any problems.
Old Oct 29, 2012 | 09:28 PM
Thanks man, I'll give it a try tomorrow I have that document, and with the drawing and noticed there are some little differences between the LH and RH drive vacuum lines, eh. So I'll look for the air pump diverter valve then.
Old Oct 30, 2012 | 04:52 AM
Had a thought since its a S2 carby car.
Has the outer casing section of the throttle cable become dislodged and sitting proud of its seat at the cardy end??. This would in effect have the carby linkage under tention, and that would prevent the linkages from returning to the idle stop position. I ask this coz it did happen to our S2 Daimler with SU carbs waaaaaay back, and frustrated the hell out of me for nearly 2 hours.
If this thing is overfueling as much as you suggest, it would need sufficient air to maintain running, or the fuel would simply flood the engine and stall it out.
The throttle plates of the carbies MUST be open for this amount of revs to be available at presumed "idle".
Old Nov 3, 2012 | 06:27 PM
Default Mr. Grant Thank You
Thanks Grant, it was indeed the throttle plates, that were stuck open. I took the carbs off and freed them up, through a little more carb cleaner in there and, then she fired up, and I was able to get the idle down to around 1000, still have some playing to do with them to tune them up.
I still cannot find where that hose goes to, I took a picture of the hose I'm talking about its the one with a yellow band on it. Any help would be appreciated.
Old Nov 3, 2012 | 08:43 PM
Attached photo of hose towards front of engine
mikiep
Dec 20, 2019 07:37 PM
tomkilner
Oct 9, 2015 07:10 AM
inactualis
Oct 2, 2015 11:13 AM
Johncy2000
Oct 2, 2015 01:05 AM
Lubrication
Oct 1, 2015 03:56 AM
