What Must Be Wrong with the Ignition Amplifier?
Old Apr 23, 2019 | 03:52 PM
mikega's Avatar
Default What Must Be Wrong with the Ignition Amplifier?
Hello good people on this platform,
Please from the attach photos, I have seen that there is smoke element or traces on the back of the ignition amplifier and the mechanic working on the also mention that there a fuse at the driver side down the dash that blown and cut off fire when the engine is running and makes the fire not stay.
Has anyone experienced this before or anyone with the idea what the problem is that causes this issue and how to fix it to get car moved?
Old Apr 23, 2019 | 04:11 PM
pjprofili's Avatar
Remove those screws and open it up. If something is fried in there it should be quickly apparent, I'd think.
Old Apr 23, 2019 | 09:42 PM
David84XJ6's Avatar
Could be shorted Radio Noise Capacitor??
Old Apr 25, 2019 | 08:24 AM
pjprofili's Avatar
David - (apologies if I'm hijacking the thread, Mike) - what's with the unit on the right? Is that an aftermarket replacement for the original? I'm intrigued.
Old Apr 25, 2019 | 01:22 PM
David84XJ6's Avatar
Yes, left is OEM; right is an after-market unit. Some one else purchased it, opened up for pictures and generously posted on the forum.
Old Apr 26, 2019 | 07:32 PM
David84XJ6's Avatar
Found the notes that go with two pictures of Amplifiers:
Left picture is Original 4 wire amplifier, with two resistors in rubber housing, just above the condenser (RFI capacitor), and the Lucas 350-volt Zener Diode is on top right corner.
Right picture is current aftermarket amplifier with (2) resistors in shrink-wrap and (2) Zener diodes in series inside shrink-wrap, grounded to left Ignition module attachment screw.
The Lucas AB14 4-wire units (DAB106) are the same as the 2 wire units (DAB102), except for 2 internal resistors circuits, one for the Tachometer (10K) and one for EFI triggering (6.8K).
The Lucas 350 volt clamping Zener diode is not available. You can wire a 190-volt and a 160-volt clamping diode in series to achieve the desired 350-volt protection. (1N5387B, 190V, 5W ZENER DIODE) ($1.10) and a 1N5384B, 160V, 5W ZENER DIODE ($1.10) (E-Bay)
Rgds. David
Old Apr 26, 2019 | 09:18 PM
David84XJ6's Avatar
Mike
Have your mechanic remove the condenser (it is just to reduce Radio Interference and not required) replace fuse and see if it will run without blowing fuse again. If fuse blows again then problem is something else. The amplifier has to be installed back on the intake while your testing, or you will have major intake leaks.
Rgds David
cel2620xl
16
Aug 8, 2018 07:26 AM
Jaguar2986
Mar 9, 2017 02:47 PM
PercyPickwick
Apr 19, 2013 04:45 PM
KevinKJT
Jun 12, 2011 05:47 PM
Tommahawk
Jun 19, 2010 09:28 PM
