What spark plugs should I be using?
Old Aug 13, 2021 | 07:59 AM
Mitzyspruce's Avatar
Default What spark plugs should I be using?
Hi.
I just bought a series II 1977 XJ12 that I going to restore.
It has been in a shed for the last five years.
I am working through everything (fluids, etc) before attempting to start it.
Could someone recommend what plugs I should be looking at using. Auto supply stores here in Victoria have not be much help, my Haynes manual doesn’t state which kind, and the the more I search the internet the more confused I get.
it’s a 5.3 fuel injected (not a HE).
I’d appreciate any help.
Cheers Steve
Old Aug 13, 2021 | 08:31 AM
NGK BP5EY is all I ever used in all my PreHE.
No need for the "R" spec plugs in that system.
Gapped at 0.030".
Old Aug 13, 2021 | 08:34 AM
Thanks Grant.
That’s where I was getting confused in regards to the need for the resistor. I’m sorted now. Thanks for the heads up.
Cheers Steve.
Old Aug 13, 2021 | 12:25 PM
JagCad's Avatar
What spark plugs are in the car now? Condition ?
V12. Fun to be had...
Carl
Old Aug 13, 2021 | 05:53 PM
Hi Carl.
Thanks for the response.
I have no idea what is there, as I haven’t removed one, all I know is that they haven’t been changed in a LONG time!
Old Aug 14, 2021 | 02:38 AM
OK, I read that and shuddered.
Get some Diesel fuel, pour a SMALL, and I mean SMALL, amount in each spark plug well.
Its now Beer O'clock.
Let it sit, 2 days if possible.
They can stick in there, especially with too many years, and unknown if Anti-Seize was used when fitting.
Unscrew 2 flats, tighten again, unscrew some more, tighten again, and so on until it will rotate 1 full turn without binding. NOW, soak up any Diesel Fuel still sitting there. You need to leave that fuel sitting in those wells as you loosen them, as it will seep down the threads on each loosen rotatation.
Take your time, snapping one off will screw your day big time.
Old Aug 14, 2021 | 03:05 AM
Thanks Grant.
Awesome advice mate.
I was going to vacuum out around the spark plug wells before I apply some diesel, just to remove any debris that may be lying there.
When you say a small amount, I was thinking using a eye dropper or something like that, so I can get it right in the spot, and not make a mess.
am I on the right track with that sort of amount of diesel?
Once again, many thanks for your input.
Cheers Steve.
Old Aug 14, 2021 | 05:16 AM
Make a mess on a V12, what are you thinking, haha.
Yes that will do, if you have one.
I used an old oil can, and filled each well as needed.
Any mess can be wiped off later. Washing that engine is a NO NO until all the electrickery is sorted.
Stu II
Aug 1, 2018 02:08 AM
jag68
Sep 10, 2017 08:31 PM
Schoe
Dec 3, 2010 06:20 AM
Leaper
Dec 16, 2008 09:05 AM
