Where does your Exhaust dump
Old Mar 1, 2016 | 05:03 PM
John Gloyd's Avatar
Default Where does your Exhaust dump
I'm running my exhaust and using 2 1/4 pipe but I can't get the turn I need going through the differential without rubbing on the axels. I'm going to dump my exhaust out in front of the rear tires. Have any of you done this? do you see any negative issues with this? If you have done this, how does it look? Am I crazy to do this?
Old Mar 1, 2016 | 05:42 PM
Roger Mabry's Avatar
Default Not very Jag like exhaust
Have it run under the IRS, that way your larger size pipe will not make a difference... can even use round mufflers in the resonator holes in the rear instead of the oval ones I used that show a little. You can use any exhaust tips but the stainless curved ones from a S3 will keep the exhaust fumes out the car with the windows down... you have to neck down the last pipe to fit the smaller size Jaguar tips.
I did this on the '72 LT1/700R I used to own and am getting ready to do this to my current car. Lot of ways to mount the pipe but it ends up like a Corvette.
Second picture is another Jaguar with the exhaust under the IRS. It is the only way to go with a Lump using good sized pipe.. side exits for pipes are not a good choice... yes it is a crazy thought!
Attached Thumbnails Where does your Exhaust dump-exhaust-under-irs.jpg   Where does your Exhaust dump-exhaust-under-irs-idea-2d-time-v-clamps.jpg
Old Mar 3, 2016 | 11:42 AM
ronbros's Avatar
my mod for big exhaust, maybe a little over the top tho!
sound is magnifcent out of 5" dia, turndown, 12 cylinders ,one outlet!
since the pic was taken i have moved the pipes higher up,for better road clearance!
mhamilton
24
Jun 15, 2017 03:51 PM
Chadly
Feb 19, 2016 05:30 PM
Kopi
Feb 19, 2016 08:41 AM
nasomi
Feb 16, 2016 10:35 PM
Sherard Big Daddy
Feb 6, 2016 06:41 PM
