Where I tie this thing down?
Old Oct 13, 2012 | 10:26 PM
lickahotskillet's Avatar
Default Where do I tie this thing down?
Dyno Day Video
Highlights
Best HP run - 485 @ 5900
Best torque - 530 ft/lb @ 4200
374 HP @ 3800 RPM
Note the crispness as Keith snaps the throttle!
So where do I tie this thing down - to the cross member?, or the inner frame/body rail?
Old Oct 14, 2012 | 07:51 PM
FastKat's Avatar
Ahhh that sounds GREAT!!!
What do you mean by tie it down? Do you mean tying the car down to a chassis dyno for rear wheel pulls, or tying a safety from the engine to the chassis?
What are you going to do for rear wheels & tires?
Old Oct 14, 2012 | 09:26 PM
Default Where do I tie the engine down?
[QUOTE=FastKat;600619]Ahhh that sounds GREAT!!!
QUOTE]
I want to tie the left front leading edge of the block to the crossmember or the inner frame/body rail. Cable or turnbuckle will go from the the bottom bolt of the A/C bracket to either.
Tires: Looking into widening the stock rims 1", running 225 or 235/60/15's. Also will run street slicks of the same size.
Old Oct 14, 2012 | 09:34 PM
FastKat's Avatar
Tires: Looking into widening the stock rims 1", running 225 or 235/60/15's. Also will run street slicks of the same size.[/QUOTE]
Ahh, that's what I thought. I would tie it down to the crossmember because that's where the engine itself is ultimately mounted. It might require some modification of the crossmember, such as welding in a piece of plate, etc.
Do you think a good set of poly motor mounts will keep the engine in check? Or do you just want a failsafe?
Old Oct 14, 2012 | 10:09 PM
[/QUOTE]
Do you think a good set of poly motor mounts will keep the engine in check? Or do you just want a failsafe?[/QUOTE]
I'm using a JCI kit. It is what I found that would allow the BBC install. I've modified the mount as in the attached picture. Note the steel sleeve added to the center of the mount. "Opinions/history" offer pro's and con's. I want it as a fail safe, and to drive the slip in the converter and at the tires, not in engine movement.
bamforp
Aug 14, 2024 05:36 PM
Jandreu
Jun 30, 2022 03:10 PM
JagLove86
Sep 6, 2015 10:36 PM
AL NZ
Sep 4, 2015 08:39 PM
