Wiring kit for ignition coil and EFI
Old May 9, 2020 | 12:34 AM
TheWarlock's Avatar
Default Wiring kit for ignition coil and EFI
Any recommendations for a wiring harness for the coils and injectors? Mine looks like it’s been spliced in multiple times.
I’m guessing TXL 16 awg should suffice? What are the oem colors for this wiring?
Old May 9, 2020 | 06:04 AM
Fraser Mitchell's Avatar
Well, you can buy these looms, but they're not cheap, probably because demand is very low.
https://www.sngbarratt.com/English/#...&saveBranch=US
Doug Dwyer runs a V12, so will be able to tell you a lot more than me. The heat of the V12 means under-hood wiring gets a lot of heat, and for an old car, a full replacement of all engine wiring is probably a wise investment.
Old May 9, 2020 | 09:26 AM
Doug's Avatar
I use GXL or TXL. As I recall the spec is the same except for insulation thickness.
16 gauge is fine. For the injectors specifically I use 18 gauge but, of course, 16 gauge would be suitable there as well
For the injector harness the key thing (more important than wire spec, IMO) for maximum durability is to move the harness off the valley floor. Most guys re-route it along the injector rail.
The S57 guides show the wiring colors. I can send you a copy if you'd like.
Finding wires with the correct colors codes takes a little searching. Lots of single color wire is offered. Wiring with tracer colors, not so much.
This outfit has quite a few choices; I just placed an order with them a few days ago. We'll see how it goes
https://4rcustomswire.com/
Colors for the injector harness are not so important, IMO, because you'll be wrapping it all up in some sort of sheathing anyway. The colors will never be noticed once your done. When you make up your new harness just keep notes on what you've done.
Old May 9, 2020 | 09:37 AM
Jose's Avatar
British Wiring has the harnesses for all Jags.
Expensive but already made with correct connectors.
Welcome to British Wiring - classic British car wiring harnesses and components
look under Product Category, Jaguar, and find your car.
Old May 9, 2020 | 09:57 AM
Doug's Avatar
Attention to V12 wiring is essential to happy V12 ownership.
In saying "....full replacement of all engine wiring..." do you mean everything in the engine bay? If so, going that far that is not needed, in my experience. But there WILL be lots of actual engine wiring needing repair or replacement, yes. It's a given.
Old May 9, 2020 | 04:03 PM
I meant the wiring surrounding and attached to the engine, for the operation of the engine itself.
Old May 13, 2020 | 11:52 AM
TheWarlock's Avatar
Thanks Doug, please keep us posted on how those turn out
xjsv12
Feb 19, 2019 04:15 AM
ryan volland
Nov 25, 2015 09:25 AM
bliving7
Jan 3, 2014 06:59 AM
jklit
Jun 10, 2009 08:44 PM
