Wood Dash Refinishing
Old Jun 13, 2018 | 09:49 PM
baudrate's Avatar
Default Wood Dash Refinishing
I just finished one of my "winter projects" . The varnish on my dash was cracking ( and subsequently the veneer). As you can see in the picture, it was very faded as well.
Here's the refinish process I used and some tips for anyone that wants to take it on.
Removal : Take care removing the dash pad. As you can see in the before picture, I inadvertently chipped some of the veneer when I pull off the pad. I had to use a patch to fix it. It's not perfect but its not too noticeable.
Stripping: Since this is a Series 1, any paint or varnish stripper will work. I used a scuff pad to help remove the varnish. Be VERY careful. I got a little aggressive and went through the veneer in several places. The old veneer was very fragile and, as mentioned, chips very easily.
Dye : I used a light walnut water based dye to lay down a background tone. This was done to give all the pieces a consistent tone. The dye is also fade resistant. The dye normally has a very red tint to it, but it went on darker than I really wanted. That's the fun of working with wood, you never know how it is going to respond. Since I didn't have anything to experiment on, it was a real crapshoot on what I was going to get.
Sealer : This was a thinned dewaxed shellac to seal the wood for the next step.
Stain : I used a dark, oil based stain as a glaze. The intent of this process is to darken the red tone from the dye. Since the dye was very dark to begin with, the stain was way too dark. Having sealed the wood, I was able to remove the vast majority of it. I just left spots to cover up the blemishes.
Varnish : I used an exterior grade, waterbased varnish. I used water based because I didn't want any yellowing that comes with an oil based varnish. The exterior grade has UV inhibitors in it as well. I put 4 coats on.
It's not perfect and a little darker than I wanted, but it is a 100 times better than before.
I also did the door caps. They turned out very nice. I'll get a picture of those later.
Old Jun 14, 2018 | 02:55 AM
o1xjr's Avatar
Nice work.
Old Jun 14, 2018 | 08:54 AM
Very nice!
Old Jun 14, 2018 | 04:27 PM
Yellow series3's Avatar
Wow. I love the new color. Very rich tone.
Old Jun 14, 2018 | 06:16 PM
Daf11e's Avatar
Well done.
Old Jun 14, 2018 | 07:43 PM
baudrate's Avatar
Here's the door caps. When I applied the dye, they were very red (as I was hoping the dash would be). I had to put 3 or 4 coats to darken it up (it was cut 50% to begin with). I was also able to use the stain to darken them. They are a little lighter than the dash, but the same tone. They should look good once back on the car.
Old Jun 14, 2018 | 08:17 PM
baudrate's Avatar
Old Jun 15, 2018 | 09:05 AM
JagCad's Avatar
Rich, very rich. Very nice. The natural grain of the wood perfectly enhanced.
Add a layer of high carnauba content wax and buff for more shine and UV protection???
I improved mine a lot by doing that. But, not as nice as this example.
Carl
Old Jun 16, 2018 | 07:58 AM
yachtmanbuttson's Avatar
Nice job! It will lighten up over time and exposure to the UV rays.
Old Jun 16, 2018 | 10:56 AM
Adrian L's Avatar
Very nice. Just a couple of suggestions: when using wood stripper, it's much better to scrape it off gently with a credit card or plastic scraper than using steel wool or scuff pad. Repeat the stripper process 2 or 3 times if need be, and be very gentle removing it.
Oil-based varnish will give an old-world amber glow to the wood, and therefore you likely don't need to use any stain. Personally I prefer oil-based varnish for this reason. I used Varathane high gloss finish on my dash.
There are purists who would be horrified at the thought of oil-based stain under a water-based varnish. Hopefully your varnish doesn't crack.
Carl: Rubbing compound and a buffer work wonders to get that piano gloss finish.
Old Jun 17, 2018 | 12:20 AM
baudrate's Avatar
Ya, I got impatient... and tried to help it along with the scrubber.
I chose to use the dye because I didn't want to just rely on the color of the wood. It was very faded and I wasn't sure if I could get that deep color I wanted. Also, since some pieces were more faded than others, I thought that they might end up different colors if I just put a coating on them.
I don't think this is as big of a deal with the newer coatings. You just have to make sure the oil-based stain is completely dry before coating it. Also, I ended up with a very small amount of the stain left on the wood.
Boilerpete
Feb 3, 2021 10:55 AM
Durwood
Apr 30, 2015 03:02 PM
robertjag
Nov 21, 2013 07:33 PM
Mazarin
Interior
Jul 24, 2008 01:35 PM
