XJ-6 Series 3 A/C Fan Issues
Old Jun 24, 2023 | 07:47 PM
Childeric12's Avatar
Default XJ-6 Series 3 A/C Fan Issues
Hi All,
I have been working through issues on my 1983 XJ-6 LHD 4.2l. The latest issue is that I can't get the A/C to blow faster than low. Occasionally, when the planets are aligned, I will get it to blow on high. It is incredibly rare and if I move the switch to low and come hack to high, I still only get low. I have pulled the relays and re-soldered everything. I even tested it, relays are fine. I checked for shorts. Guys, I am out of ideas. Anyone have any ideas to help? I appreciate any and all help!
Old Jun 24, 2023 | 08:57 PM
Doug's Avatar
Does this occur only in "Auto"? Or only if "High" is manually selected? Or both?
If only in " Auto" I suspect the brains of the system are not commanding the high speed operation....although it should be noted high speed would only be commanded when max cooling is called for. High speed is not used when the system is in heating mode or blend mode.
Otherwise I'd suspect a problem with the mode switch.
Old Jun 24, 2023 | 10:32 PM
Right now, if I put it in anything, I get only low. Occaisionally, it will blow on high.
Old Jun 25, 2023 | 05:24 AM
Greg in France's Avatar
What happens on defrost?
Old Jun 25, 2023 | 07:46 AM
Jose's Avatar
probably the large Fans Relay. Replace relay and try again.
Old Jun 25, 2023 | 09:29 AM
Same.
Old Jun 27, 2023 | 10:10 PM
So, I tried 3 different relays. Pulled the switch and checked the microswitches. Turned out to be a loose negative wire on the bottom of the climate control switch. Thanks for everyone's suggestions!
mikega
Oct 29, 2021 09:28 AM
rdssdi
Oct 28, 2021 07:46 PM
Trevor123
Nov 30, 2020 08:29 PM
Jose
Oct 28, 2014 02:58 AM
simonious
Apr 10, 2011 08:59 AM
