Xj6 centre hub removal?
Old Aug 10, 2021 | 01:22 PM
jamie ward's Avatar
Default Xj6 centre hub removal?
Hey guys how do I remove the center cap on the xj6 wheel hubs
Thanks in advance!!
Old Aug 10, 2021 | 01:29 PM
jamie ward's Avatar
Also side note, would anyone know the process used on the inside of the wheel hub , aswell as how the centre hub is "painted" black or would anyone have a good link to some good paint fot it
Old Aug 10, 2021 | 05:58 PM
The Mekon's Avatar
Simple, lever off the retaining clips - most likely destrying them in the process. Buy new ones on ebay if you cannot find them anywhere else.
Your hub caps seem to have seen better days. They look like series 2 caps to me. I have 6 of these in better condition. Would be free to anyone who can pick them up. Unfortunately I do not believe we live near each other, but someone closer may offer caps at a similar price.
Old Aug 11, 2021 | 09:35 AM
yachtmanbuttson's Avatar
I find that with a pair of needle nose they will come off by gently pulling up and unscrewing. Just be careful as you can break the plastic stud if man-handling.
Old Aug 11, 2021 | 09:36 AM
And... If you do break the stud, JB Weld does the trick. Ask me how I know?
Old Aug 11, 2021 | 09:48 AM
jamie ward's Avatar
Cheers , managed to get it off, as you said it broke the retaining clips , how much would a new set , set you back? A few parts of trim and that need rechroming , I thought it may have been more economical to do it my self , as there's no where local that can do it and a lot of local forms say to send it to England which can get pricey
Old Aug 11, 2021 | 11:52 AM
jamie ward's Avatar
yeah ... I found out the hard way... but jb weld does the stuff ? At least its only one stud ... I want to repaint the back center caps too, any idea what process was used or what paint to use?
Old Aug 12, 2021 | 06:26 AM
Use the original JB Weld not the Quickset stuff if you want it to be long lasting. Not sure what you are trying to paint? Mine are chrome on the outside, paint on the inside. Seems to be a red primer.
Old Aug 12, 2021 | 06:38 AM
jamie ward's Avatar
I want to paint the black part , not sure how to restore the centre black bit
Old Aug 12, 2021 | 02:55 PM
All I did was mask out what you didn't want painted and rattle can spray painted a semi-gloss black. Looks fine.
Old Aug 13, 2021 | 08:08 AM
jamie ward's Avatar
Great thank you , you guys are so helpful
iramphal
Feb 13, 2019 03:09 PM
skid
E type ( XK-E )
Jul 18, 2018 11:51 AM
Greg Gray
Feb 25, 2018 09:28 AM
oldmainsfishing
Aug 9, 2009 05:09 AM
