XJ6 Fuel Pump Hell
Old Apr 19, 2012 | 03:40 PM
Mr. Pink Computer Shrink's Avatar
Default XJ6 Fuel Pump Hell
Hello,
I just replaced the fuel pump in my 1992 XJ6 (again). I started the car while it was still up in the air and it was running fine. Shut it down.
(I had to re-seat one of the fuel lines to get it to stop leaking.)
Started it again and it ran for a minute or two then stalled. I dove under the car and saw the fuel line connecters were all sealed up. :-)
Tried to start it a again, no go...
It blew the fuel pump fuse.
Has anyone heard of OEM fuel pumps shorting out in 5 min or less?
When I disconnect the fuel pump and turn the ignition on the fuse does not blow.
Help!
Scott Christopher
Old Apr 19, 2012 | 04:31 PM
Default OK, not the fuel pump...
Now it gets fun.
I am blowing the C8 25A fuse when the car is running after about a minute.
I just pulled the tank, got the pump out and tested it a less than 2 amps.
I hooked up the old pump and it tested at less than two amps.
Can anyone send me a schematic that shows where fuse C8 is going?
All this after setting up the return of the new fuel pump...
Help!
Old Apr 19, 2012 | 04:58 PM
C8 is listed as FUEL PUMP CONTROL / LAMBDA SENSOR
Old Apr 19, 2012 | 05:18 PM
Default Solved!
When the connect to the Oxygen/lambda sensor flops over and melts to your exhaust manifold, C8 Blows!
Putting my gas tank back in now...
Old Apr 19, 2012 | 05:49 PM
Good to hear you got to he bottom of it.
dsnyder586
Dec 29, 2024 07:39 PM
Sprayall
May 30, 2021 08:13 AM
Kmw
Sep 8, 2015 04:52 PM
deanh
Sep 6, 2015 08:20 PM
Sprayall
Sep 3, 2015 07:49 PM
