XJ6 Series 1 - Fuel tank - why not?
Old Mar 9, 2018 | 04:43 PM
Norboy's Avatar
Default XJ6 Series 1 - Fuel tank - why not?
Dear fellowmen and women, - novise on this forum, happy to join and learn/share experiences.
Now - fuel tanks and water..., we've read and experienced all, water entering our fuel tanks, drain pipes clogged, o-rings dried out, rusty tanks, engine struggling etc etc.
So - I am thinking where does all this water actually enter the tanks?
I am no hydrologist or plumber -not even technically skilled, but it struck me that (least on my own 69 series 1 - see image) the top of the neck of the tank filler hole (A on image) appears to be positioned far too low - at (or even below) level of the wing (B) - it simply allows water "flowing" in...
Therefore - I'd be happy if it could be explained to me why the height of the the neck of tank the fill hole (still A) - is not higher - more elevated relative to the wing (B) - obviously because I think this would simply prevent water from "flowing" directly in.
Would a possible solution be to increase the height of the neck (A) at least 1, maybe 2 centimetres above level og B, and would this prevent (or minimize) the amount af water entering tank? (All the above remedies of drain pipies, O-ring etc etc in addition of course).
Happy to hear comments.
Attached Thumbnails XJ6 Series 1 - Fuel tank - why not?-xj6-tank-filler-neck.jpg
Old Mar 9, 2018 | 04:57 PM
Jose's Avatar
Something does not look correct.
is it possible that the rear wing was replaced with a Series 2 or Series 3 wing and the neck hole does not match the tank's neck?
Old Mar 9, 2018 | 08:44 PM
Roger Mabry's Avatar
Series 1 filler caps are much different than S3 caps. Have both photos somewhere... but the S3 necks are much longer and take different filler caps when S3 tanks are used..
Old Mar 10, 2018 | 07:29 AM
Norboy's Avatar
@Jose - may be you re onto something. For sure something not all right. The wing is original (only one-owner car...), however the tank might have been replaced (series II tank?) - could that possibly explain "gap"?
@Roger - dont know, but guessing-if tank has been replaced-a serie III ank would not fit a series I-right?
Norboy
Old Mar 10, 2018 | 08:06 AM
Tank would fit fine, have them in my car, but you need the S3 caps. Check your tanks for a return line that is blocked off unless you have fuel injection.
Old Mar 10, 2018 | 06:49 PM
Jose's Avatar
I removed a cap off today and I looked at it, it looks identical to Norboy's car!! that is, the neck is below the sheetmetal, does not stick up over the hole.
86jag
May 12, 2023 07:06 PM
dleckste
Sep 2, 2021 07:23 PM
Undertaker
Feb 24, 2014 01:19 AM
jdoc84
Oct 15, 2012 06:28 AM
amcdonal86
Jan 19, 2012 10:00 PM
