XJ6 Series 3
Old Jul 19, 2012 | 10:09 AM
Geoff's Avatar
Default XJ6 Series 3
Hi,
Has anyone got any idea where the electric window relay would be on a 1986 xj6 series 3 sovereign?
Many Thanks
Geoff
Old Jul 19, 2012 | 05:48 PM
icsamerica's Avatar
Default consider this
My recollection is that the relay is under the center console bolted to the shifter plate. The relay simply powers up the circuit when the key is in the on position. The polarity change to get the window to go up and down is done by the switches. You can confirm it's location by looking at the colors of the wiring, the relay should have similiar colored wiring as the window switches.
Old Jul 19, 2012 | 06:50 PM
Jose's Avatar
I think they are behind the front left or right kick panels?
Old Jul 19, 2012 | 07:43 PM
Doug's Avatar
The window relay...on LHD Ser IIIs at least...is at the extreme right side of the dashboard. Remove the right side under-dash panel and (as I recall) the plastic end trim at the right end of the instrument panel. Now look upwards, to the right of the glove box.
Old Jul 21, 2012 | 09:48 AM
Geoff's Avatar
Thanks a lot everyone, I'm going for a look now.
Old Jul 22, 2012 | 03:48 PM
Geoff's Avatar
Thanks very much Doug, You were spot on.
Geoff
pnwrs2000
Jan 15, 2018 07:20 PM
alextoevs
Sep 20, 2015 05:21 PM
ahunt4
Sep 19, 2015 09:49 AM
ahunt4
Sep 19, 2015 06:46 AM
