xk engine turns over, locks up then fires?
Old Aug 16, 2015 | 05:46 AM
jjd's Avatar
jjd
Default xk engine turns over, locks up then fires?
Folks my 420g 4.2 on triple carbs occasionally turns over locks up momentarily then fires into life. Im told its a timing issue that can be rectified by moving the distributor? Is this the case and how is it done? I have posted in mk10 /420g section but its quiet over there and seeing as its essentially an inflated xj im hoping someone here has an answer. Cheers jjd.
Old Aug 16, 2015 | 10:57 AM
Doug's Avatar
Yes, if the base timing is too far advanced it can cause what you describe. Try retarding the timing a bit.
There's a clamp device that holds the distributor body stationary. Loosed the clamp and turn the distributor body anti-clockwise just a smidgen...maybe 1/8". Tighten clamp.
See if the symptom is reduced.
Retard the timing a bit more if needed. You can go back and forth to find the sweet spot....as you don't want to retard the timing more than needed. Doing so can reduce engine power and increases fuel use.
Ideally a timing light would be used to first check the original setting....so you can go back to that setting if needed. Lacking that you can make a reference mark of some sort on the distributor body
If no improvement consider the possibility that the starter is getting weak....as a very similar symptom can occur.
Old Aug 16, 2015 | 11:19 AM
Curt Lee's Avatar
Has anyone moved any of the spark plug leads? Mine did the same thing and I discovered the PO had reversed the leads on the cap, as if the firing order were front to back. Lucky I didn't do any damage continuing to attempt starting it.
Old Aug 16, 2015 | 03:49 PM
jjd's Avatar
jjd
Cheers doug ill give that a try. The leads are in the correct position and she runs well when started. I see a circular clamp at the base of the distributor so ill mark up and try a bit of rotation. The starter is a refurbished unit so it should be ok.
Old Aug 16, 2015 | 07:09 PM
amaezing's Avatar
You can also loosen the clamp, hold it in place(premarked somehow), have someone else start it, and gently turn it as it is running to find your sweet spot..Hold it there, have them turn it off and retighten the clamp.
That should save back and forth trips and keep that dirty grease off your keys and steering wheel.
BrentGardner
29
Dec 16, 2024 12:13 AM
Drew2006
Nov 24, 2015 11:14 AM
msdg137
Sep 16, 2015 06:24 AM
cheaperts
Aug 30, 2015 06:48 PM
SingBlueSilver
Aug 27, 2015 02:20 PM
