1977 XJS flasher unit
Old Jun 22, 2019 | 12:43 AM
nudge61's Avatar
Default 1977 XJS flasher unit
Hi, can anyone help with a wiring diagram for a 77 flasher unit. I have the workshop diagram but it only shows the relay and not the flasher unit wires. Any help is greatly appreciated.
Old Jun 22, 2019 | 04:41 AM
Kriss Vector's Avatar
Default Hope this helps
You need # 25 Let me know if you need anything,,,
Old Jun 22, 2019 | 05:38 AM
nudge61's Avatar
Thanks for the response, but I have a flasher unit which only has 3 wires going to it. The wiring diagram i have shows a relay as being no 154 and says that 25 is part of it????
Old Jun 22, 2019 | 05:49 AM
I have a 1976 a 77 should be the same car, the flasher is a small black box located right on top of the fuse box, it is mounted to the top of the fuse box with 2 small nuts and bolts ( tiny ) is that what you are looking at?
Old Jun 22, 2019 | 06:23 AM
nudge61's Avatar
How many wires are going to it? I think you are talking about the relay.
Old Jun 22, 2019 | 08:36 PM
Bez74's Avatar
Hello Nudge
My electrical drawings also show that the flasher unit is 25 which is part of 154
Part 154 is the Hazard warning flasher unit
Believe what you are asking is the black box closest to the drivers door - which has 3 wires coming out of the bottom.
About centre of the photo
I have not traced these wires yet - so I could be wrong
If you can send some photo's through of the E type jag motor set up under that XJS - I would love to see that carb set up
Steve
Old Jun 22, 2019 | 09:56 PM
nudge61's Avatar
Thanks for that Steve, that really helps. I will send a few pics through shortly. I retrofitted the AC compressor down on the driver's side above the alternator.
Old Jun 22, 2019 | 10:30 PM
nudge61's Avatar
Hi Steve, mine appears to be different, I have the same wiring diagram, which says that 25 is part of 154. But i have three wires coming off from the loom with a 3 post tridon flasher unit which was blown by a shorted wire at the ignition amplifier.
Old Jun 22, 2019 | 10:48 PM
nudge61's Avatar
Old Jun 22, 2019 | 11:32 PM
Bez74's Avatar
That is just beautiful
AVSeal
Feb 11, 2021 08:23 AM
adenshillito
Mar 5, 2017 12:59 AM
TonyC
Feb 7, 2015 03:02 PM
NTL1991
XJ40 ( XJ81 )
Jul 27, 2013 03:19 PM
Simprof
Apr 18, 2013 04:21 PM
