1982 XJS - Both sides power windows not working
Old Aug 2, 2014 | 04:47 PM
Stein Erik Hanssen's Avatar
Default 1982 XJS - Both sides power windows not working
Hi, I have a problem with my 1982 LHD XJS.
Both sides power windows stopped working at the same time. I guess my car have a circuit breaker, but i cant find it in the fuse department under the glove-box.
Where should I find it?
Old Aug 2, 2014 | 05:18 PM
Doug's Avatar
You're in the right area. Keep looking. Look for brown and brown/blue wires.
This might help:
http://ww2.justanswer.com/uploads/NA...15159_ssss.jpg
You're looking for the square-ish 'thermal breaker'
Old Aug 2, 2014 | 06:25 PM
malc4d's Avatar
picture here
https://www.jaguarforums.com/forum/x...roblem-122067/
Old Aug 3, 2014 | 04:49 AM
Thanks a lot.
The problem turned out to be the relay. Both windows worked when I jumped 87 - 30 (brown-blue wire).
I think I will remove the relay, its only function is to cut the current/power when ignition is off. Not a function I need or want to have.
Old Aug 3, 2014 | 05:21 AM
Greg in France's Avatar
Originally Posted by Stein Erik Hanssen
Thanks a lot.
Better to replace it, if I may be so bold. Having full battery current in the system all the time is not necessarily good news if something else 'downstream' shorts out. Cheap insurance?
Greg
Old Aug 3, 2014 | 06:33 AM
What could possibly go wrong?
Ok, your are right. Changing relay is cheap and easy. I think i might even have one or two somewhere...
chipnping
Mar 8, 2016 10:33 PM
johnnie ryall
Oct 19, 2015 09:44 PM
msdg137
Sep 16, 2015 06:24 AM
ahunt4
Sep 4, 2015 02:59 AM
