1982 xjs - wont turn over!
Old Dec 26, 2013 | 02:08 PM
jfpctrees's Avatar
Default 1982 xjs - wont turn over!
Battery is strong and charged, good connections, ignition turns on, lights & radio work, fuel pump runs for 2 or so seconds - however no sound from the starter when the key is turned to start position. Faint click sound from under the dash - wont turn over! Any thoughts?
Old Dec 26, 2013 | 02:52 PM
jimbov8's Avatar
If you are sure about the battery then check the ground on the starter.
Have someone try to start while you put a meter on the battery to see what the voltage drops to.
Old Dec 27, 2013 | 02:44 AM
Greg in France's Avatar
There is an inhibit microswitch on the gear selector, this might have got out of alignment. Just worth trying to start her in neutral, as opposed to park, if you have not already tried to. The inhibit switch might be Ok in neutral.
Also, the electrical bit on the back of the ignition lock might be worn out. Also worth trying about 25 goes of the key - start and off star and off - quickly to see if that revives the contacts.
After that, test to see if the key signal is reaching the relay . Under the bonnet, RHS under a black cover on the wing, near the screen.
Greg
JarodL
Mar 7, 2024 01:39 AM
kevinl
Oct 31, 2019 06:15 PM
mbergen
Oct 23, 2019 10:26 PM
ahunt4
Sep 14, 2015 08:17 PM
Saturbo
Sep 8, 2015 07:35 PM
