1988 5.3 xjs overheating
Old Sep 6, 2018 | 01:10 PM
Shahar Alon's Avatar
Default 1988 5.3 xjs overheating
hey guys
so i change the radietor hoses (all of the 14 hoses)
no leaks from there, i replace the 2 thermostat and the car get overheat
any idea what i should do next ?
Old Sep 6, 2018 | 01:46 PM
Steve M's Avatar
You have to make sure that you bleed the system properly otherwise you will get air pockets.
Also, did you fit the correct thermostats? They should have 'jiggle' pins in that will allow the air to escape the system; the thermostats should be mounted with the pins at the top.
Old Sep 6, 2018 | 02:03 PM
Greg in France's Avatar
Did you:
  • Clean out the radiator fins and those of the aircon condenser and oil cooler which are in front of it.
Old Sep 6, 2018 | 05:04 PM
sidescrollin's Avatar
Was it overheating before?
If NO: you have air in the system or the wrong thermostats
If YES: check your fan clutch
a
Sep 14, 2020 08:31 PM
slburns538
51
Aug 16, 2019 10:49 PM
SeanPeterLynch
Jun 28, 2014 04:04 AM
orangeblossom
Mar 30, 2014 05:29 PM
Pete
Oct 10, 2010 08:35 AM
