1988 5.3 xjs overheating
You have to make sure that you bleed the system properly otherwise you will get air pockets.
Also, did you fit the correct thermostats? They should have 'jiggle' pins in that will allow the air to escape the system; the thermostats should be mounted with the pins at the top.
slburns538
51
Aug 16, 2019 10:49 PM
orangeblossom
Mar 30, 2014 05:29 PM
