1988 Brake Master Cylinder Brand Question
Old May 6, 2012 | 04:56 PM
Terrymadtown's Avatar
Default 1988 Brake Master Cylinder Brand Question
I am going to replace the brake master cylinder on my 1988 XJS and I have a question about the brands that are out there. I have found 3 brands TRW $146, Centric $179, and Beck Arnley $211. Is there any difference in the units? I do not mind spending the extra money if there is a need to do so but if they are of the same quality why spend the extra money?
I will also replace the fluid with DOT 4. I am also thinking of replacing the hoses at this time. Is there a hose kit or can I replace them with off the shelf hoses?
Is there anything else I will need to do at this time.
Thank you.
Old May 6, 2012 | 06:22 PM
Doug's Avatar
Unless someone chimes in with specifics I think it'll be a toss-up regarding the brands. Nowadays "label engineerng", world-wide manufacturing/distributng networks, and endless corporate buy-outs and mergers make it difficult to really know what you're getting, who made it, or where.
TRW is generally known for quality stuff (FWIW, as mentioned above) and is the cheapest. I'd go for that one.
Hoses should be available from any of the usual Jag suppliers, no problem.
How are your calipers?
Old May 6, 2012 | 07:22 PM
M90power's Avatar
one place i would just check real quick. Rob beere racing. cheap OEM stuff comes through their bargain bin every now and then.
Old May 7, 2012 | 12:20 PM
I took the tires off and looked at the rotors and I did not see any problems. Do I need to do more than that?
Old May 7, 2012 | 09:42 PM
Greg Edge's Avatar
I would buy the TRW one. Beck/Arnley stuff is mostly re-boxed OEM and priced usually higher than dealer list.
There is a new Jaguar unit on ebay right now for $155.
Wolfy
May 28, 2024 08:06 AM
mbergen
Oct 23, 2019 10:26 PM
PMKimpton
Aug 3, 2019 08:22 PM
KarimPA
Sep 12, 2015 08:15 AM
obwoodie
Sep 3, 2015 07:45 PM
