1989 XJS Cold Weather Gremlins
Old Jan 3, 2010 | 12:51 AM
BlackJack's Avatar
Mine had suffered with a nearly identical set of problems, as you note impossible to troubleshoot because of the intermittant nature.
It was a crap shoot on whether the car would run perfectly, or act like one bank of 6 cylinders was running, or if it would just drop you at the side of the road and never start again....Until you let it sit, call the tow truck and he shows up....and then it would start.
I do not have the extreme temperature component as affects yours, but mine may have been somewhat temp related also.
But I'll cut to the chase. After months of searching, it turned out to be the blasted main brain--the ECU that lives in the trunk (boot). Replaced it with one from JaguarHeaven, and the problems went away, never to return.
From the sounds of your problems, it might just be the ECU. Hope this helps.
Lou
Old Jan 3, 2010 | 11:43 AM
Doug's Avatar
Originally Posted by chipkent
Thanks for the help! I'll see what an ECU costs to see if I want to roll the dice on it. Random part replacement drives me nuts but seems to be the norm on the Jags.
Its the norm on any car (or dishwasher, or computer, or anything) if fighting an intermittent problem. The only other choice is to hope the problem gets worse and/or more frequent so that a decent diagnosis can be performed.
My tolerance for guesswork is usually dictated by my pocketbook. A $25 or $50 guess is one thing. A $250 or $500 guess is another :-)
Old Jan 9, 2010 | 01:36 PM
BlackJack's Avatar
I've been thinking about your set of symptoms, and they sure do sound electric / electronic in nature. Especially the parts about intermittant cessation and returning to normal, just like mine did, with no seeming rhyme nor reason to it.
Maybe someone on this board has an extra ECU lying around you could try...?
Old Apr 26, 2014 | 02:05 PM
1800doogie's Avatar
Default Sorry to bring up an old thread!
Have been reading the entire site and love it! May help another owner. In 2000, I had a 82 xjs. It would always start, but would die at random! At times, wouldn't start at all! I had no internet, but had a Hemmings, and called a guy who advertised jag knowledge. He said " Its the tps, jag updated it, you need a new retrofit". Did it, and never had a problem again! Took the old one apart, and it had carbon everywhere! Worn thru tracks too! Check your tps, as well as the other recommendations! Hope this helps someone.
SD96XJ6L
Jan 12, 2022 04:30 AM
42Ajd
Dec 30, 2015 09:45 AM
vinny jones
Oct 5, 2015 07:20 AM
42Ajd
Sep 21, 2015 07:37 PM
1100me
Sep 7, 2015 06:26 AM
