1990 Jaguar XJS - Downpipe to Intermediate Connection
Old Jun 11, 2022 | 10:02 AM
JayJagJay's Avatar
Default 1990 Jaguar XJS - Downpipe to Intermediate Connection
Hey All...
It been a while now. Sometime ago I got lucky enough to find a set of OE Jag catless downpipes (thanks to Greg) from eBay Euro. I installed them (like the result) but what I've been struggling with is the downpipe to intermediate pipe connection. 3 point flange, terrible connection, and they both eventually will leak.
They guy I had do the intermediate to downpipe only pissed me off at the time of install, I paid him less than what he asked - he would NOT listen to me...
Before I go out and buy something (I have the worst luck trying to buy exhaust materials - limited understanding) I wanted to run this by y'all to tell me what you think...
Here is the part, or something like it, that I have been looking at. Is the size right first off,,, 1 7/8ths,,, and can I bring a set like these to a exhaust guy, and with relative ease (his) expect that they can be made to work?
Money is an object here... I want a leak-less thing, without anything fancy shmancy. Something that will function, is reliable and doesn't LEAK, matters more.
Give me some direction!
Old Jun 11, 2022 | 10:19 AM
Robbo D's Avatar
On my car the down pipe to intermediate pipe is bolted together with an olive between the flanges. I have just had my exhaust off to sort out and it all went together fine with new bolts and olives. I used ceramic grease on all the joints which is good for up to 1200 degrees C so if I need to remove in the future it will be easy.
Rob.
Old Jun 11, 2022 | 10:45 AM
Doug's Avatar
I recall that the downpipes are 2.25" so the 1.875" couplers would be too small. I'm sure similar couplers are available in a larger size.
Exhaust shops are not all the same and, IME, tend to be a bit stubborn. I obviously don't know what exhaust shops are available in your area. I would suggest seeking out a shop that caters to the hot rod/street rod crowd. IME, they're more imaginative in how they solve problems and more willing to accommodate customers' wishes. But, yes, more expensive, generally.
That said, I wouldn't be too quick to write-off the flange-and-gasket joining method. They've been leak-free on my V12 for several years now. But, OTOH, poor workmanship can obviously compromise the effectiveness of any method.
JayJagJay's Avatar
Rob.
I have a few olives (supposed to be for the XJS) but they don't seem to be right size for the "cup" on either side... I think the guy (the intermediate pipes were new) cut the intermediates and added a new section where it meets the down. I was not and am not happy with his work.
What the guy used and what's there is some kind of crappy soft-ish gasket. It will never work for what's there.
What size olive?
Old Jun 12, 2022 | 08:25 AM
JayJagJay's Avatar
Got ya Doug. Thank you. That's exactly the kind of information I was looking for and need...
I need to BUY something and have someone install them.
So, with Euro catless down pipes I can expect (and I will measure once at the car of course) them to be 2.25 inches or 57mm?
I needed clamps for the rear most silencers to over axle pipes in re-installing after dropping the axle and they were/are 1-7/8ths... So,,, its what I was basing my (bad) thinking on....
Damnedest thing,,, I have a SNAP-ON mig welder that I have never and am AFRAID to use, lol. I need to get over it and start welding!
Old Jun 13, 2022 | 11:17 AM
Rescue119's Avatar
what doug said..... go to a car show and ask where the locals get their exhausts done or drive to ones and if the have a bunch of muscle cars in the lot chances are they are good
wish i knew you needed some exhaust parts. i tossed all mine last year in the bin.
JayJagJay
Sep 20, 2019 09:59 AM
revski666
Feb 5, 2017 08:35 AM
thuffner3
Apr 10, 2012 10:24 AM
expedio2005
Apr 3, 2011 07:43 AM
tbone
Oct 13, 2010 09:14 PM
